Hyper TT 4wd 1/10th Truggy Thread
#3196
Also...
anyone think a castle 4-pole 4600 motor with 16t pinion on the blue delrin spur will cause heating issues or would this be good? ESC will be an MMP.
#3197
Here is what I have so far. Please let me know if you see anything I did wrong and should change as this is my first electric kit. I know the servo is crap but the one I ordered won't be here till Monday and I want to test it out tomorrow. All input is very much appreciated.
Rear Diff 2000wt
Center Diff 5000wt
Front Diff 5000wt
14t pinion
2s 5000 40c
CC SW 3800
Rear Diff 2000wt
Center Diff 5000wt
Front Diff 5000wt
14t pinion
2s 5000 40c
CC SW 3800
#3198
Rear Diff 2000wt
Center Diff 5000wt
Front Diff 5000wt
14t pinion
2s 5000 40c
CC SW 3800
Rear Diff 2000wt
Center Diff 5000wt
Front Diff 5000wt
14t pinion
2s 5000 40c
CC SW 3800
#3199
The body dropped right on. I tried putting the esc on the servo but it would'nt fit with the fan on it. When my new dremmel shows up i'm gonna grind down the sides of the fan so it sits closer to the esc then i'm gonna move it to the servo. It will probably stay cooler up front. Thank you for your reply.
#3200
#3201
Rear Diff 2000wt
Center Diff 5000wt
Front Diff 5000wt
14t pinion
2s 5000 40c
CC SW 3800
Rear Diff 2000wt
Center Diff 5000wt
Front Diff 5000wt
14t pinion
2s 5000 40c
CC SW 3800
-Tony
#3203
What wings fit on this truck? Dont like the stock one....
Thanks...
Thanks...
#3204
has anyone come out with alloy front hubs for this yet?????
#3205
Losi Ten-T
http://www.amainhobbies.com/product_...ware-Set-Ten-T
The holes line up, but they are larger on the Losi wing. Cut a thin slice of fuel tubing or use an A-arm shim or something to center them.
-Tony
-Tony
#3206
Rear Diff 2000wt
Center Diff 5000wt
Front Diff 5000wt
14t pinion
2s 5000 40c
CC SW 3800
Rear Diff 2000wt
Center Diff 5000wt
Front Diff 5000wt
14t pinion
2s 5000 40c
CC SW 3800
He did not even have a fan on the esc..
#3207
Losi Ten-T
-Tony
-Tony
#3208
The Tekin RX8 ESC will work fine mounted on the servo,you just have to angle it slightly to clear the servo arm..
#3210
Foams require a bit of work and a tyre truer if you can't find pre mounted.
At our track race rules state we must use stock wheels so premounts are not an option.
So the process is lathing of the wheels to remove regular tire mounting ribs, glue on tires, trim tire edges and then true to correct size.
Strikers just glue on - use associated truck foam inserts with them (asc7880)
