Hyper TT 4wd 1/10th Truggy Thread
#2371
yes I have the SCT in my 10TT...so far so good, racing season hasnt started yet...but for our track (tight, technical, low traction) it is working well.
I have the stock spur with a 13T pinion now, running cool, but a little harsh on the bottom end....I am going to try a 14T on my next practice session.
I also need to get my Castle Link running and try to tone it down a little on the bottom end...Anyone have recommendation on their SCT settings?
#2373
Replacement 10TT Tires
Probably been posted already, but need to ordeer quickly. Need to replace the stock TT tires with? JCONCEPTS gold / pink?
LOSI BK Bars?
This is for indoor track use only
LOSI BK Bars?
#2374
Stock tires are actually pretty good, the foams are the crap part....swap out the foams and rock em for a while.
I have had good luck with J Concepts Bar Codes green on indoor clay, fairly high bite depending on time of day. Most of the racers at the local track are running the Double Dees in green and the comments are that they are much more forgiving if the traction lets up a bit when the track dries out.
#2376
o
I found a dynamite system with 3300kv a speed passion citrix with 3600kv and the CC SCT system....be honest what do you all think would be the best...it is an outdoor track medium sized...any and all opinions appreciated thanks
#2378
#2381
I have a AWESOME Hyper TT in the for sale section. $250 shipped with alot of hopups and new tires. PM if interested. http://www.rctech.net/forum/r-c-item...races-old.html
#2382
Well..
I got my TT yesterday.. Spend an hour or two getting it running.. Decided to take it into the front yard and take it up and down the block a few times..
So i decided to come down the street full speed, up my drive way, onto the lawn, (this is tall fluffy lawn, not golf course lawn).
Well when it hit the edge of the lawn it flipped up into the air and landed on its lid. (Mind you i didn't have the body or the wing on)
so i turned the truck over, and the shock tower was bent to hell, the rear chassis brace broken, and my rear center drive shaft was bent. Pretty sweet first outing.
#2383
Well..
#2384
you can try this place. crazy price. it lets you put it in your cart like they have them in stock, but i didn't go through the whole check out process.
http://www.gonitrohobbies.com/Castle...10-0090-00.htm
#2385
I went to the track the the day with the TT......I was nervous since everyone says how fragile they are......going down the back straight clipped the pipe and WHAM into a railroad tie!
BUT.....the TT took it like a champ......off I go again after a few laps I decided to get brave and try to triple the jumps.......cased the top of the thrid and flipped high into the air, end over end, over end over end down the track it goes for about 20 feet
Walked over and flipped it back on his wheels and off he went
So far the little guy took 2 pretty rough hits......100% stock 10TT just boiled all the arms, carrier and knuckles.
I dont think this little guy is the toughest out there by any means....but I dont think they are made of glass like a few guys make them out to be either.
