Team Associated RC8Be Thread
#1321
I looked at the end bell on the shaft end, and it's held in place with 3 screws, so I would think that I could rotate it.
Got the MMP wired up. I don't have a fan, but it's really cold outside. I was thinking of doing a few high speed runs and measure temps after each pass. If it starts to creep up, I'll just wait until I get a fan, then retest. There is certainly a lot more room for the MMP!
If all the tests go well, I'd like to try a sensored motor so I can run SmartSense to get the best of both worlds.
#1322
Yup; that's what did with mine!
#1326
Jees, how much did you sand it? I didn't have to take any out on mine. And it doesn't leak anymore.
#1327
#1329
#1330
So I sanded the diff halves until the whole surface had that matte look so I knew it was even. I used the clear seals and coated them with black grease and I still get the weeping that a lot of people talk about. I'm hesitant to use the mugen gaskets cause of the few people that wrote about their diff not being as smooth due to the extra thickness. any other suggestions?
#1332
I filled my centerdiff so the gears was covered in fluid.
But what do you mean with the halves? I guess you are talking about the "ring" that makes the housing for the diff where the spurgear mates with it?
#1334
im still having a small leak out of mine to.im gunna try some 600 grit one more time.and the last time i sanded i only went to 350 grit and used some greese around paper gasket and gently snugged the halves together,making sure not to tweek the plasic,but it didnt work.oh and i even used new spur and new gasket.
#1335
Just got done testing the MMP. The final results are after 8 to 10 minutes of pretty aggressive driving (speed passes, lots of braking, lots of acceleration, etc):
Motor 167F
Batt 96F
ESC 150F to 165F, depending on where I aimed the temp gun
Ambient temp is 32F
Specs:
5S 40C 3000mAh Zippy LiPo
MMP with 1800kV Neu motor
No airflow provisions in the body
46T spur with 21T pinion
Also this is without a fan on the ESC. I had to remove the fan for it to fit in my RC10B4. If I decide to keep the MMP in the RC8Be, I'll order a new fan for it.
I'm charging up a 6S now to give it a try.
As for the leaking diffs, I filled mine up just past the spider gears. Some did come out when I assembled the diff (from being slightly overfilled, I assume), so I cleaned that up after I tightened the screws (I tightened them as evenly as I could). I let the diff sit overnight and no leaking. Also no leaking after a post run inspection. Before I used the Mugen gasket, the diff showed signs of weeping after I let it sit overnight.
Motor 167F
Batt 96F
Ambient temp is 32F
Specs:
