Team Associated RC8Be Thread >
Old 05-28-2011 | 04:30 PM
  #6181
DRUNKENMASTER's Avatar
Originally Posted by ROBBSRACING
Hey guys I need a little help here. I am helping a friend put together a
FT RC8BE. He has a Tekin RX8 with a T8. The wire that goes from the ESC to the receiver seems to be to short. The ESC is mounted so the wires are as close as they can be. The plug just pokes through the receiver box. I have double and triple checked the routing of it and there is no way its wrong or could really go any other way to help. I spoke to a tech at Tekin and he said it should be 10 inches long. I took it apart and measured it and it actually measures 10.5 inches yet its definitely still to freekin short. I thought about using a servo extension but I just dont like that idea much. Plus the plug is like half in half out of the receiver box. No good.
Instead of running the wire over the bridge try running it behind the front chassis brace. No extension needed. Like this >
DRUNKENMASTER is offline
Old 05-28-2011 | 04:31 PM
  #6182
pbomstad's Avatar
I use a 12" servo extension the plug end is back by speed control and I just coil up the 10" lead for the speed control. It rides fine sitting behind the battery.
pbomstad is offline
Old 05-28-2011 | 07:11 PM
  #6183
Registered User
Default Evil Empire
Originally Posted by Sarinexia
Yep, I don't trust this guy.
+1
Does this mean I can't date your sister? LOL
Its a good file Im a newbie who has been getting allot of info from here. In order for me to disimante data I have to see it all in one place. So I thought it would be nice to share with you all.
MX
MXBEEBOP is offline
Old 05-28-2011 | 07:24 PM
  #6184
jwmustang's Avatar
I tried to unzip, did not work.
jwmustang is offline
Old 05-28-2011 | 08:17 PM
  #6185
toyoter91's Avatar
if you want to route it the way its suppose to be routed, a servo cable extension is going to be needed. Myself and a few other guys at the track have all been running a 6 inch extension with out any issues.
As you can see it allowed me to have extra slack through out the routing and I like that as it shouldn't wear any of the cables due to being so tightly routed around the corners and up and around things. It also allows me to remove either the radio box, or the battery tray one at a time with ease.
toyoter91 is offline
Old 05-28-2011 | 09:40 PM
  #6186
CRCDUDE's Avatar
Ive been runnin my "E" buggy like this for 3 yrs now. No problems
CRCDUDE is offline
Old 05-29-2011 | 08:29 AM
  #6187
rc person 577's Avatar
Originally Posted by MXBEEBOP
I wanted to share a few Excel Sheets I created.
In one I consolidated all the Data from the Hudy setup guide to one sheet for quick access.
The other I consolidated many of the published setups for the RC8B and this can be sorted by track type.
I hope some of you find this help full. I've gotten allot from this thread time to give back.
Downloaded it with no problem. Looks helpful, nice job!
rc person 577 is offline
Old 05-29-2011 | 10:07 AM
  #6188
same here. thanks for the effort.
loopdog is offline
Old 05-29-2011 | 11:01 AM
  #6189
anyone get your update part yet ?
taztal3 is offline
Old 05-29-2011 | 05:06 PM
  #6190
racer25's Avatar
So in my rc8be i threw in a mamba monster with a tekin 2650kv t8 and some good hitec servo all i need is a battery now. Im deciding between a 4s or a 5s for mainly indoor, which should i use? i want the most power but im thinkin a 5s with a 40c from reedy or a 4s with a 90c from orionthe mah on both is above 4000
racer25 is offline
Old 05-29-2011 | 05:30 PM
  #6191
How about I suggest a 3s instead?
Old 05-29-2011 | 06:18 PM
  #6192
PTP Racing's Avatar
5s and 2650kv ought to be complete insanity
I got out today to try all the changes I made to my car and it really made a huge difference. The rear was completely planted. From the stock setup I went to black rear springs, the upper hole in the rear hub, the lowest inner hole on the rear tower for the camber link, and 3 degrees anti-squat.
PTP Racing is offline
Old 05-29-2011 | 06:39 PM
  #6193
toyoter91's Avatar
I second the 3s suggestion lol.
I run 3s with a 2250 and its more then enough.
Old 05-29-2011 | 06:41 PM
  #6194
racer25's Avatar
from the sound of the past 2 answers i think 4s would be better i just want the max amount of power out of it
racer25 is offline
Old 05-29-2011 | 06:42 PM
  #6195
racer25's Avatar
or 3s alright ill start with the 3s then go from there thanks!
racer25 is offline
