Team Associated RC8Be Thread >
Old 03-15-2011 | 08:08 PM
  #4351
kufman's Avatar
Originally Posted by nexxus
Any ideas on gearing / tyre set up for Grass Track Racing?
running an RC8Be, MMP, 2200kv Castle Motor, DS1313 Servo, 4PL Radio on 4s Lipo.
Have a set of Badlands and AKA Crossbrace on Corr style Rims but not sure if either of those are suitable for Grass.
Also any general set up info? Are Tapered pistons worthwhile?
You will want to look for tires will bigger lugs for grass racing. I don't know if I would go all the way to Badlands, but they do work. Just have to be careful when you turn since they tend to dig in and cause traction rolling. I have a set of knockoff Badlands and they are great for the grass. Crime Fighters and Calibers also make decent grass tires.
For gearing in the grass, I would start out around 44/16 or 44/17 with that motor. Grass is hard to predict. Taller grass will require a smaller pinion to control heat. For dirt use, an 18 or 19 pinion would be perfectly normal. I would start low and monitor the temps. If you find the motor and ESC temps to be right around 100F, you can go to a taller pinion.
On a side note. You may need some capacitors on your receiver if you are using the MMP's BEC with that servo.
kufman is offline
Old 03-15-2011 | 08:10 PM
  #4352
kufman's Avatar
Originally Posted by W1KK3D
Can you run a MMP on 1/8 scale? I have one that I was saving for the SC10 4x4 but if I don't have to buy another esc...
It works pretty good in 1/8th scales. I have been running my MMP in a 1/8th for about a year with no problems. For high power servos (coreless, digital in particular) you may need a capacitor to help the BEC or you can use an external BEC.
kufman is offline
Old 03-15-2011 | 08:38 PM
  #4353
nexxus's Avatar
Super Moderator
I found the MMP was fine with that Servo but not the 1015 which the SC8 has (MMM Speedy) but I have put a Spektrum Cap in anyway.
Grass track is usually very short and well maintained which is why I queried using the AKA tyres. Badlands I was told trimming the outside lugs and dropping ride height would help with traction rolling?
nexxus is offline
Old 03-15-2011 | 08:47 PM
  #4354
schnellschnell's Avatar
Finally snapped a few pics of mine. Inside and out.
Attached Thumbnails Team Associated RC8Be Thread-crw_5094.jpg   Team Associated RC8Be Thread-crw_5095.jpg
schnellschnell is offline
Old 03-15-2011 | 08:49 PM
  #4355
per4m28's Avatar
nice bug!
per4m28 is offline
Old 03-15-2011 | 09:01 PM
  #4356
symmetricon's Avatar
nexxus, you want the 1.1 tapered piston. This was personally recommended to me by an AE driver. they allow for faster rebound. 30wt front bronze spring 25wt rear silver springs
symmetricon is offline
Old 03-15-2011 | 09:38 PM
  #4357
buggy8's Avatar
new look
buggy8 is offline
Old 03-15-2011 | 10:51 PM
  #4358
Brazie's Avatar
Default Noob rc8be jumping!
+ YouTube Video
Brazie is offline
Old 03-15-2011 | 10:52 PM
  #4359
Brazie's Avatar
Default noob jumping again haha!
+ YouTube Video
Brazie is offline
Old 03-16-2011 | 01:50 AM
  #4360
Smile Lipo
Needing some advice, i am running a RX8 with a 2050 motor. What Lipo would suit best?
What would a Gens Ace 4s1p 14.8v 40c be like?
Anthony.
Handbrake is offline
Old 03-16-2011 | 02:02 AM
  #4361
Manshoon's Avatar
Anthony.
Bad, just bad bad bad..................Fast bad, but bad bad bad
Manshoon is offline
Old 03-16-2011 | 02:58 AM
  #4362
nexxus's Avatar
Super Moderator
Care to elaborate? Seems like a good set up to me.
nexxus is offline
Old 03-16-2011 | 05:26 AM
  #4363
Ripped's Avatar
Dam that was alot of parts.. But, I got it done..
[IMG][/IMG]
Ripped is offline
Old 03-16-2011 | 06:40 AM
  #4364
Suspended
Default Stripped Screws
So I took out all my electronics last night for some light cleaning before my track day next weekend (actually all weekend since wife will be out of town!!). When tightening the screws on the radio tray I might have stripped those two out (stripped the head of screw). Where do you guys buy screws at? I saw some on towerhobbies but I don't need 10 of them. Does anyone sell a complete set? Maybe Stainless Steel?
slash_me_up is offline
Old 03-16-2011 | 06:41 AM
  #4365
Suspended
Default Upgrades
I know we had this discussion but I have some extra $$ to blow again on this buggy. I am already ordering the grid mount. What one do I get? I see there are two of them. I wanted the one with the support but I am running a 20-21 gear. I have all DE stuff. What other suggestions?
