Team Associated RC8Be Thread >
Old 02-27-2011 | 02:31 PM
  #3601
schnellschnell's Avatar
Originally Posted by 117
I think Gregg has charged batteries at 2C and up before.
Really. I read the specs as being able to handle 5C input rates so I charge them at that. As it was explained to me, LiPos have advanced significantly to be able to accept higher rates than even a few years ago.
Reason why you are using lower rates? 1C must take a long time for a 5000mAh battery.
j
schnellschnell is offline
Old 02-27-2011 | 02:34 PM
  #3602
117's Avatar
117
It depends on the battery brand. Some say 1C to 2C max, and some say 5C max. I would look to see what the manufacturer recommends.
117 is offline
Old 02-27-2011 | 02:53 PM
  #3603
per4m28's Avatar
j
You can charge lipos as what the manufacturers say....but charging at 5C definitely will shorten the life span of your battery....as batteries has different charging rates I always charge at 1C for maximum life but in a jam you definitely can charge at higher C's to battery spec.
per4m28 is offline
Old 02-27-2011 | 03:20 PM
  #3604
117's Avatar
117
This is exactly why I charge at 1C. I'm in no big hurry, so why not charge them at a rate that will maximize the batteries useful life.
If you're in a hurry to charge multiple batteries, you can always parallel charge them.
117 is offline
Old 02-27-2011 | 04:55 PM
  #3605
GreggW's Avatar
I usually charge my Gens Ace at 10 amps.
GreggW is offline
Old 02-27-2011 | 05:25 PM
  #3606
Default 4200 45c hyperion
just wondering if u guys think this would be a big enough batt for a 10 or 15 min main with a tekin 1900 or 2050 and on RX8 thanks
hitman72 is offline
Old 02-27-2011 | 05:27 PM
  #3607
GreggW's Avatar
I usually get close to 20 minutes out of my 5000mah Gens Ace.
GreggW is offline
Old 02-27-2011 | 05:33 PM
  #3608
Cain's Avatar
Tech Legend
battery life is track and driving style dependent. I have seen plenty of people get 20 minutes + on a 5000mah 4S, and others on the same setup get 12 minutes.
Cain is offline
Old 02-27-2011 | 05:48 PM
  #3609
+1
agarabaghi is offline
Old 02-27-2011 | 06:25 PM
  #3610
jwmustang's Avatar
Also depends on your gearing. Mine is 46/18 get 18 to 20min MMax 2200,HK Nano 5000.
jwmustang is offline
Old 02-27-2011 | 06:27 PM
  #3611
Default TEKIN
hmmm thanks guys on the batt help what about speedo getting an rx8 but still sounds like they r having a ton of problems with them still what do u guys think
hitman72 is offline
Old 02-27-2011 | 07:11 PM
  #3612
jasons36's Avatar
I've had 3 and never had a problem with any of em. I think with a few exceptions the majority of failures is due to user error or abuse. Don't kid yourself, mambas fail too!
jasons36 is offline
Old 02-27-2011 | 07:51 PM
  #3613
So after a few cycles the GensAce looks much closer in cell gap. However discharging below 3.7v they really start to lose voltage cohesion. Now I set my cutoff to 3.8v so it isn't much of an issue, but I do wonder if that is normal.
And duly noted on the charge rate, I thought that new batteries were more flexible wrt lifetime/charge rates. And I just got the new charger and 24v of power. Guess its time for more mAh batts!
j
Old 02-27-2011 | 08:01 PM
  #3614
117's Avatar
117
I've had an RX8 for a little while, and no problems with mine. You're going to see failures regardless of brands, but the RX8s did seem to be problematic a year or so ago. I think they've worked out most of the bugs since then.
That said, I know Gregg has an issue with his that will hopefully be taken care of by Tekin this week.
117 is offline
Old 02-27-2011 | 08:51 PM
  #3615
GreggW's Avatar
They should have gotten mine on Wednesday. I keep forgetting to call though. I'll check on it tomorrow, if I remember. I'm not sure what happened to mine. I did talk to a guy at the track last weekend that was very familiar with them he's been running the 3 he has ever since they upgraded to the 3 hole case, and hasn't had a problem. And I've seen him out that the track every weekend and he races all day. He was telling me the older cases didn't hold the 2 boards together that are inside well. The new case apparently has some supports built into the bottom of the case that keep the 2 boards from separating inside the case. He said the older cases allowed the 2 boards to unplug from each other. And when that plug gets loose with power applied it that smokes the boards. So most of the failures were apparently caused by this older style case allowing the boards to come apart. The new case is supposed to hold these boards together tight.
GreggW is offline
