Team Associated RC8Be Thread >
Old 01-31-2011 | 11:09 AM
  #1756
GreggW's Avatar
Originally Posted by brandon1116
god i hate when people say the 2650 is too big of a motor for the track just tone it down on your computer i got mine set up at 60 punch running a 4s battery and the thing is amazing on the track but im running the hyper 9e. I would way rather have a larger motor for when i wanna bash instead of running a smaller motor and have to run it on 6s
Never said anything about "too big" it's just a big motor for a track. And I agree you can turn it down. For track only smaller motors are more efficient and use less battery.
There is a huge difference between a weekend basher that goes to the track and strong arms the car around the track with a big motor and someone that races with precision for the lowest lap times.
GreggW is offline
Old 01-31-2011 | 11:27 AM
  #1757
blade329's Avatar
R/C Tech Elite Member
I just bought a used RC8Be from another rctech member. Can't wait to try it out. I'm mainly a Ve8 guy, but I've also ran a Losi 8ight. Should be interesting.
blade329 is offline
Old 01-31-2011 | 11:38 AM
  #1758
GreggW's Avatar
Mine are the same way. I think the right is a manufacturing defect. And my blocks are pretty loose. Scroll up some, Billy posted where he shimmed his up a little. When I get time, I may do this too.
Originally Posted by Sarinexia
Bit of a question guys:
I'm assembling my RC8be and I have two questions: (fairly small)
Please reference the PDF instruction manual link:
http://teamassociated.com/pdf/cars_a...eft_manual.pdf
Page 9 Steering Block - when the CVA bone is secured in Steering Block, well, my left spins fairly freely, the right a bit choppy. Is this a big deal considering there will be 32k rpms pushing this? (I thought I might have got lock tite in there, maybe a drop onto the bearing, but barely anything if anything at all... I'm 99.9% sure no effect.)
Page 10 (the big question):
When the steering block is inserted into the caster block is there supposed to be any play side to side with the Steering block? I did insert the key bushing properly. The side to side play isn't exactly free flowing and the screw moves that secures the block bushing.
a. should there be any play in this?
b. and if there is some play, (movement side to side) does it matter?
From what I gather the steering block inside the caster shouldn't move. At all. But there is a little play. Is this a big deal?
GreggW is offline
Old 01-31-2011 | 11:41 AM
  #1759
117's Avatar
117
Run the car for a battery or two, then check the hub bearings. Mine freed up significantly, and now there's a bit of play that wasn't there before. It doesn't seem to hurt anything, but I'd rather not have the additional play. I thought about using some higher quality bearings, but I have other stuff to do first.
Side-to-side play in the steering block? Do you mean play that is parallel to the steering king pin axis (I think of that as more up-and-down play, rather than side-to-side)? If so, then that seems to be fairly normal. Mine was the same way. It's too bad that AE didn't try to use some type of bearing in the caster block. The steering rack is very well made and slop free. It would be nice if the caster blocks and steering knuckles were the same way.
Good luck with the build!
117 is offline
Old 01-31-2011 | 11:44 AM
  #1760
Suspended
Good to hear I have company. I wondered because it was inconsistent with one another and i knew there was a problem. With the way the axle spun in the steering block and the way the steering block moved in the casing. It keep me looking over every detail and rebuilding over and over again last night (about an hour). But, yep.... good to hear I'm not the only one.
So far i really like how Associated gave us the tirods pre-assembled at the correct length. That's a plus. I hate trying to twist those end plastic pieces on. Just a neusense. Saved me some work.
Sarinexia is offline
Old 01-31-2011 | 11:47 AM
  #1761
GreggW's Avatar
It won't be long until you are twisting on some new ones. I broke my right rear the first time on the track. Good to keep spares of these things.
GreggW is offline
Old 01-31-2011 | 11:48 AM
  #1762
bazthecarman's Avatar
Default price
Besides used which I don't want to do, right now what is the website that sells the rc8be factory team kit for the least amount. For the people who just bought their rc8be's where did you buy them???? Right now the lowest i have found was $329. just don't want to get ripped off.
bazthecarman is offline
Old 01-31-2011 | 11:49 AM
  #1763
Suspended
on page 10, top illustration where the steering block goes into the casing. From looking at the diagram, picture left to right, right to left movement. It's not exactly "free" movement, but it does move and the key bushing seems to have a role in this (as I tried it experimentally without the key bushing and a str8 screw in... then there was no movement at all. I didn't think that was right either.)
PS - the key bushing was a pain in the..... to line up.
  #1764
117's Avatar
117
I just had a thought...I could try turning down those steering king pin bushings in my lathe, but they're very tiny. I'm not sure I could accurately set them up in the chuck.
One could try sanding them down a bit, but that could take a long time (not to mention it would be difficult to hold them).
117 is offline
Old 01-31-2011 | 11:50 AM
  #1765
Suspended
Originally Posted by bazthecarman
besides used which I don't want to do, right now what is the website that sells the rc8be factory teamm kit. For the people who just bought their rc8be's where did you buy them???? Right now the lowest i have found was $329.
329? then jump on it. I just got mine from towher for 359.00.
Where you see it for that? ebay? Are you including the shipping cost?
Old 01-31-2011 | 11:51 AM
  #1766
117's Avatar
117
$329? That's a heck of a price. Don't think you're going to find it cheaper than that anywhere. Where did you find it for $329?
117 is offline
Old 01-31-2011 | 11:54 AM
  #1767
Suspended
Oh, i got spares :-) More than I prefer to have
Old 01-31-2011 | 11:57 AM
  #1768
Suspended
Btw Gregg,
I took a look at that diff case. Oh yeah... it's visible to the naked eye. The casing (you can tell) is definately machine cut. There is evidence of plastic burrs on each one of the diffs I built.
I took 600 grit sandpaper to all of them on a flat hard surface as suggested. I too think this will prevent any leak problems.
although, that paper gasket seems next to worthless, although, I know a very important part. I think it's promising there won't be any leaks. I didn't see reason to buy a new gasket.
Old 01-31-2011 | 11:59 AM
  #1769
+1 I'd like to find this out too. I'll sell my rc8 e-conversion in flash to jump on this deal.
eddiemoney13 is offline
Old 01-31-2011 | 12:00 PM
  #1770
Default setup
hey toyota 2jz just a few questions:
1.Is that a mamba max pro 1/10 scale esc (even though i pretty sure all mamba max pros are 1/10 scale)
2.what batteries do you use
3.whats the kv on the motor
