RC10B4.1 FT/WC
Old 05-15-2012 | 09:47 AM
  #14806
Chad Smith's Avatar
Thanks for the replys!
Chad Smith is offline
Old 05-15-2012 | 09:54 AM
  #14807
supafastsupra2 did you grind away the lip on the shock collar to sit on top of the traxxas insert or did you dremel away enough room for the lip to fit inside of that piece? Hope that question makes sense...
gguertin145 is offline
Old 05-15-2012 | 11:18 AM
  #14808
ovalracer1m's Avatar
no grinding needed, the traxxas uppers fit perfectly over the lip....
ovalracer1m is offline
Old 05-15-2012 | 12:02 PM
  #14809
Wildcat1971's Avatar
I have an old school B4 FT (not a 4.1). What would I gain with the new 4.1 worlds that would be useful for local club racing?
Wildcat1971 is offline
Old 05-15-2012 | 12:21 PM
  #14810
Guest
yes it will make a big difference in handleing, stable!!!!!!!
LOSIRACER77 is offline
Old 05-15-2012 | 12:24 PM
  #14811
It really all depends on the track. Personally I prefer the Old Car and I am faster with it. but I have only tried others B4.1 WE and not my own.
jdeadman is offline
Old 05-15-2012 | 12:46 PM
  #14812
Chad Smith's Avatar
Most importantly you will have a new car!
There has been alot of changes since the b4 I would just buy the Worlds kit and have all the updated parts, +8mm chassis etc.
Old 05-15-2012 | 01:39 PM
  #14813
LOSI123's Avatar
Does anyone know the lowest tooth count that will fit (pinion and spur teeth added together)?
LOSI123 is offline
Old 05-15-2012 | 01:47 PM
  #14814
The biggest thing is the longer chassis:
http://kriostasis.com/store/index.ph...f1d76dfebea7e0
Krio is offline
Old 05-15-2012 | 03:19 PM
  #14815
D-Rek07's Avatar
Originally Posted by D-Rek07
Would the regular clay compound tires work on a blue groove clay track that isn't watered?
Originally Posted by Krio
What brand?
proline MC suburbs
D-Rek07 is offline
Old 05-15-2012 | 09:06 PM
  #14816
DanielC.'s Avatar
The Traxxas collar is slightly larger ID than the OD of the bottom of the threaded associated collar. No dremelling required
DanielC. is offline
Old 05-15-2012 | 09:16 PM
  #14817
Why would you want to know this?
I'm running 69 spur and 31 pinion. I really dont think you could get a smaller spur. The slipper pads are right at the edges, but the 31t pinion is the size of a nickel. But it sure runs great with a 13.5
zipperfoot is offline
Old 05-15-2012 | 09:28 PM
  #14818
brent701's Avatar
I know a 20/84 is cutting it close.
My t4.1 runs 20/84 and the motor is all the way forward and is at the min amount of gear mesh I would want to run.
brent701 is offline
Old 05-15-2012 | 09:43 PM
  #14819
hanzo3's Avatar
What parts do I need to get to convert my b4.1 to the worlds edition?
hanzo3 is offline
Old 05-15-2012 | 09:48 PM
  #14820
easy e's Avatar
I'm surprised to see so many people running the MC compound, they seem to hard to me..
easy e is offline
