RC10B4.1 FT/WC
Old 03-08-2012 | 11:23 AM
  #12541
davidfast's Avatar
Originally Posted by Bob Barry
I can't confirm if Losi 56 pistons are = to AE but I can tell you that the number refers to the size of the drill bit that is used to make the hole. AE number 2 is a 56. so I believe it's 1 55, 2 56, 3 57 but I always get 1 and 3 backwards LOL. That's what I get for running 2's everywhere (and why I keep a manual in my pit box :P)
as far as limiters... they affect your weight transfer alot. I am a bit rusty on the details for that too, but I know that you definitely want to look at that aspect of it as well. If you can't find anything, shoot me a PM so I remember to get the info for you tonight. I know I have it saved somewhere at home
AE #2 is a 55
http://www.teamassociated.com/pdf/ca...ankpistons.pdf
davidfast is offline
Old 03-08-2012 | 11:28 AM
  #12542
Originally Posted by davidfast
why you dirty rat.......................
proving me all wrong and stuff
I should have video'd me rebuilding my diff last night. First diff rebuild since 2003 ROFL. that's what happens when you take a long time off hahaha.
wonder if I can get this one to last another 9 years
Bob Barry is offline
Old 03-08-2012 | 11:33 AM
  #12543
davidfast's Avatar
LOL longest lasting diff on record
Old 03-08-2012 | 11:35 AM
  #12544
DaveW's Avatar
Something else i ran across this week putting my T4 back together. B4 and T4 shocks downtravel are near identical once assembled with suggested limiters.
I took my B4 v2 shock bodies and installed unshimmed T4 shock shafts in them and they were within 1mm of downtravel of suggested shimmed complete T4 v2 shocks.
For other reasons i wouldnt run it this way (uptravel limiting and shock shaft stroke centering and support), but i thought it was interesting nontheless.
DaveW is offline
Old 03-08-2012 | 11:44 AM
  #12545
mxracer458's Avatar
Will the losi 56s drop right in the ae shocks?
mxracer458 is offline
Old 03-08-2012 | 12:00 PM
  #12546
Yes, but you will need a very small spacer to go above or below the piston. The diameter is the same but the the losi pistons are a hair thinner.
Many of us have been running the Losi pistons with great success, they have less play in the shock and suck less air as a result. My shocks have never lasted longer then they have since I put in Losi pistons.
Kave is offline
Old 03-08-2012 | 12:15 PM
  #12547
idrummerboy13's Avatar
the old xxx pistons or the new tlr ones? I will try some=]
idrummerboy13 is offline
Old 03-08-2012 | 12:22 PM
  #12548
mxracer458's Avatar
Have to be the old xxx shocks the 22s are big bores
  #12549
joelwhite's Avatar
old
joelwhite is offline
Old 03-08-2012 | 12:24 PM
  #12550
aeRayls's Avatar
thanks bob,i was looking at chad dues reedy set up,since i run at west coast and just wanted to see what the difference was between the losi56 and ae #2s were,i just can't spend 20 bucks on 4 pistons lol
$20 on 4 pistons??? Where you gettin those? lol. A set of Losi 56 pistons is less than $4 at amain...
The best part about the Losi pistons is how tight and smooth they are in the shock bodies. I religiously run them in my truck, I go back and forth on the buggy because I already have a couple great setups I run.
aeRayls is offline
Old 03-08-2012 | 12:47 PM
  #12551
HAHAHA I wish. It was just that long since I built one. I took a long time off.
As my buddy Chris says, I went to bed, woke up and everything was different!!! I still catch for not understanding why my motor had 3 wires coming off it I swore they were messing with me
Although this current one I just had to rebuild was built by a buddy back in Sept
Old 03-08-2012 | 12:53 PM
  #12552
so how do you change your shock setup if you are running Losi pistons. Running same weight oil or you did you bump up?
Are you running 55's or 56's.
Old 03-08-2012 | 01:50 PM
  #12553
mxracer458's Avatar
The best part about the Losi pistons is how tight and smooth they are in the shock bodies. I religiously run them in my truck, I go back and forth on the buggy becauseT I already have a couple great setups I run.
I was talking about the gheA pistons for 20 bucks
Old 03-08-2012 | 02:39 PM
  #12554
CraigMBA's Avatar
Originally Posted by Wild Cherry
BB springs are actually softer at first , explaining that extra grip & plush ride they bring...
WC is infering that one spring (TLR) is more progressive than another (AE). While there are exceptions, it's not the case given the springs we use.
Below is a picture of three springs. Which one of these springs is on your RC car? Which one of these is progressive? (this is a trick question)
This is a picture of a TLR5167, the yellow rear that is popular with folks who are doing the BB conversions. Does this look like the spring in your car, and which spring does it resemble in image above it?
For our application, springs are linear until you physically collapse or buckle them - either into coil bind, or when they deflect so much it effectively shortens their physical length (what you are doing when the spring drags on the shock).
Yes, I'm simplifing, and yes, I know users can google search up research like this, but I submit this isn't critical to understand the concept, nor is it the point WC is trying to make.
But we know progressive springs exist, right? I mean, people claim "this spring is more progressive" all the time. And they do - here's what they look like in real life (on a real short course or trophy truck):
Note the fact there are two separate springs on that shock. This is what makes it progressive - two physically seperated springs with different wire size and a different number of coils per inch.
There are springs marketed as progressive in RC cars too - I even own some. Problem is, even the this HPI spring isn't progressive because it compresses at a linear rate. Don't let the physical shape fool you, the spring would measure exactly the same rate if the coils were all equally spaced because the spring uses the same wire throughout.
The nuts and bolts on how a progressive spring works is this - at the beginning of the travel, the spring rate of the softer spring is the spring rate - not a combined rate. The softer spring compresses first, the second one might as well not be there. At some point the softer spring compresses so much, it's effective rate becomes equal to the stiffer spring (in the example of the King shock, its when the softer spring has totally colapsed into coil bind and the spring rate of the softer spring goes to infinity) . Then the spring rate of the second spring comes into play, and increases the effective spring rate to the second springs rate.
What that means is anyone telling you constant wound springs as more progressive, or less progressive is selling marketing hype; or worse - doesn't know what they are talking about, because the only way to make progressive springs is to use two springs that are physically removed from one another.
A few have said the improved performance is due to the fact they do not rub the shock body less .
Not so...
and
now you now know why ...
Well, we know something - WC is advocating something that is exactly opposite what our resident AE mechanical engineer/spring development guy has to say on the subject:
Originally Posted by patiofurniture
Aside from the springs rubbing there are other benefits to the BB springs. Since they are a larger diameter, for a similar spring rate the willingness for the spring to buckle reduces substantially, and therefor decreases any side loading that would be imparted onto the shock (also causes the rubbing). This side loading increases shock shaft drag and reduces the amount of force being transferred to the tire.
Who is a user to believe?
WC is right about something - the spring is softer, but it's softer all the way through the travel. This is why some users are having trouble with the BB conversion - their spring selection is softer (too soft) relative to what they were using before.
IMO, it was difficult to run a rate much lower than 1.9 conventional (AE rear Green) because the spring would buckle and it would cause the chassis to handle erratically when the spring hit the shock. By comparison, when I measured it, the 2.0 big bore (TLR yellow) was at least 15% softer (it's more than that, but no, you can't copy my homework - I already told you too much).
This is why I continue to beat this dead horse, and advocate all users check and rate their own springs. Google is chock full of examples on how to do it, and if you don't, you will never know when somebody in the manufacturing process made a mistake somewhere along the way - (which I had happen on my TLR white springs). When I converted to big bore springs, my chassis handled exactly the same before and after converting from AE to Losi springs because I carefully made sure they had the same wheel rate in the truck. The biggest change is my chassis jumped a whole lot better. That made my chassis more consistant, and thus lowered my lap times.
If somebody disagrees with me, I wish they would go to the same trouble I did with WC and use cites to prove me wrong (if I did get it wrong, which I don't think I did else I wouldn't of wrote anything). We are all entitled to our own opinion, but not our own facts, myself included, and even I get it wrong from time to time. Suffice to say, I went to a lot of trouble and expense to find a match for AE greens. And it's not TLR yellows.
CraigMBA is offline
Old 03-08-2012 | 02:56 PM
  #12555
T-BirdJunkie's Avatar
From: Norwood, OH...and CCRCR and The OhioRCFactory
Originally Posted by CraigMBA
wall of text and some pictures
Craig, that dual-spring coilover pictured is not progressive. It's dual rate. In general, there is not enough room in RC shocks to have an actual progressive coil. Most of them are dual or triple rate IF they have any progression at all.
T-BirdJunkie is offline
