RC10B4.1 FT/WC
Old 02-22-2012 | 01:01 PM
  #11776
Littlejohn Dsgn's Avatar
My brother ran one in his non worlds B4.1 and it fit, just fit, but it did fit. And the CC stuff will work fine, no reason to drop more money unless you want to
Littlejohn Dsgn is offline
Old 02-22-2012 | 01:06 PM
  #11777
Originally Posted by jurquhart
thanks....I guess I'll try and sell my Castle esc. I have a tekin RS Pro I can put in it instead with a redline 8.5 motor. I'm not familiar with the LRP stuff but I'll look into it.
lrp is top of the line you will not be disappointed and their customer service is phenomenal
JoshCorti11 is offline
Old 02-22-2012 | 01:47 PM
  #11778
Originally Posted by JoshCorti11
I am not really familiar with the castle creations stuff because most racers don't use castle crations and especially if you have that brand new worlds kit I would recommend a lrp sxx v1 or v2 comp spec 100x better than castle creations stuff and a lrp 9.5 motor
What is wrong w/ the Castle Creations stuff? I have a Mamba Max Pro in my RB5 SP2 and love it... What edge does LRP have? CC and Novak seem to give the biggest bang for the buck.. and very respectable brands.. Now Castle motors I won't do... I much prefer to have my sensored motors (Tekin Redline and Novak Ballistic)...
LoudOne is offline
Old 02-22-2012 | 01:49 PM
  #11779
brent701's Avatar
Originally Posted by Bob Barry
Car should rotate better and jump further
What he said
Originally Posted by jirish617
eh...not a whole lot, very minimal if hardly noticeable. It was a good thing if anything because my car had a little too much, and i needed some push. i've actually been meaning to switch back to the trailing axles to see what i notice now that I've been driving with the in-lines for quite awhile now. I love how the car handles, has the perfect amount of steering, just need a taaaaaaaaaaaaaaad bit more rear traction upon corner entry but not so it grabs too hard. Which reminds me, I know it has been brought up wayyyyyyyyyyyy back, but i am currently running 1* anti-squat, what kind of change would I see if went to 2*
It will also give you a little more on power traction
I run *2 . 2.5 toe block and *0 hubs
brent701 is offline
Old 02-22-2012 | 02:05 PM
  #11780
opio's Avatar
I'm only giving MY honest opinion here but Castle is for bashers, novak motors don't seem to hold power for very long, tekin seems a tad on the slow side too. Now all that could be my set-up, but that is just what I have found. LRP has great customer service and there esc's are pretty bullet proof unless you get one of that bad batch that was just out. Now I am partial to this brand but if you want bang for your buck try Viper. Trinity D3 motors are fast too.
opio is offline
Old 02-22-2012 | 02:10 PM
  #11781
the edge that lrp has is more tuning options there smoother and just very well known would you ever see a pro running castle stuff not trying to be mean about this but lrp is obviously better than castle creations.
Old 02-22-2012 | 02:18 PM
  #11782
Just because pro's do not run it does not mean it cant be competitive, maybe this guys only racing club races. If CC stuff is what you have try it before selling it. I find that if you have working gear (no matter what brand) it normaly comes down to driver skill. The fast guys at my local track could kick my but with a manual speed control
Old 02-22-2012 | 02:38 PM
  #11783
I hear you... but I don't race professionally... The Castle Link program is enough for me.. I am a carpet racer, so the Mamba Max is plenty for me..
LoudOne is offline
Old 02-22-2012 | 02:40 PM
  #11784
My set up
Im running 2 degree camber on all 4 tires
Shock weight is 30 front 27.5 rear
Springs front brown rear green
Shock positions rear: Tower inside axle outside, front: tower inside axle outside
1/2 oz behind battery 1/4 oz next to reciever 1/2 oz in front
What does ajusting the ballstud positions do and mines a rtr
It pushes really hard on power and needs more rear traction at points when going fast.
Also how in the world to people run like 90% brake i had mine on 40% and slide out really easy when just barley tapping the brakes so i run at 25% now
By the way im just getting into the sport so dont know to much about setups
Ive seen some people put the c hub for more traction would that be a good idea
This is the track i race at http://www.youtube.com/watch?v=p9DSBxBF8Zo
chancejeff is offline
Old 02-22-2012 | 02:57 PM
  #11785
Originally Posted by chancejeff
My set up
before you do anything else. Move the rear shocks in on the arm and then make sure your shocks (all 4) have 2 limiters in them. Start there.
Radio setup will vary according to your electronics but rule of thumb is higher bite = higher brake epa. Lower bite = lower brake epa. Basically you have to lower it so you don't spin out when you grab the brakes hard. Start running drag brake. It will make you faster (is what everyone tells me anyway lol). I myself am just starting to run it so I'm not that experienced with it yet. I picked a setting of 5 to start on my LRP SXX v3 with 3.0 software. My epa on my brakes will be 80-90 depending on the track. I run it as high as possible without spinning out.
EDIT: also run 1/2 a deg of camber all the way around. maybe 1 tops.
Bob Barry is offline
Old 02-22-2012 | 03:14 PM
  #11786
I have several sizes of limiters so which one though
Old 02-22-2012 | 03:23 PM
  #11787
B.A. Racer's Avatar
.030..they are black
B.A. Racer is offline
Old 02-22-2012 | 03:39 PM
  #11788
Motofan747's Avatar
ANYONE?
Ya definitely go with the LRP ESC. The best ESC in my opinion, and dont even want to compare to a CC. I would go with the reedy motor. They are known to be slower than the LRP motor, but are known to be smoother, and stay cooler. Also practically none of the pros run them now. Maifield switched form lrp to Reedy
Motofan747 is offline
Old 02-22-2012 | 03:43 PM
  #11789
actually alot of the pros are switching from reddy to the lrp x-20 lrp is always one step ahead of the game. look at the pics closely from the reedy race
Old 02-22-2012 | 03:47 PM
  #11790
the .30 is the smallest and you will want to use 2 of them the .60 is bigger and is like using 2 .30s and the largest is .90 and that is like using 3 of the .30s I would recconend use a .90 or 3 .30s in the front and then .60 limiter in each of the rear shocks.
