RC10B4.1 FT/WC
Old 02-08-2012 | 09:13 PM
  #11101
DaveW's Avatar
Originally Posted by Jake S
hummmm new lrp motors??
http://www.lrp.cc/en/products/electr...d-75t/details/
vector x20... look seeexxxxyyyy
Damn... and i love my x12's! Must purchase!!
DaveW is offline
Old 02-08-2012 | 09:14 PM
  #11102
DaveW's Avatar
Originally Posted by jf+
A Google search gave no clear help..
What's the difference between setting the throttle (soft, normal, hard, max) on my ESC vs. setting the trim on the gun? Specifically, if I handicap the motor using one or the other, am I causing problems (heat, harder on the motor, etc.) using one method over the other, or does it not matter?
I'm sure someone with years of experience can shed some light.
What speedo?
DaveW is offline
Old 02-08-2012 | 09:15 PM
  #11103
pink_sleeve's Avatar
Originally Posted by bilster44
The steering spindle for the hex conversion takes "no" spacers as it takes up the whole space inside the caster block. If one wanted to raise or lower the hex steering block, you would have to shave the top or bottom of the steering block to be able to space it up or down.
Or the proline spindles can be used for those who want adjustment.
pink_sleeve is offline
Old 02-08-2012 | 11:48 PM
  #11104
brent701's Avatar
Originally Posted by Teambcw
Way more then just the chassis.... You also get the +8 body and the ballast weight and you get the factory team 0* hubs.... that's like over $50 bucks in things that are better then the standard kit, that's not even counting the cost of the chassis.
Well yeah. I didn't list all of it due to it already being listed 10+ times but people are lazy to look for the info
brent701 is offline
Old 02-09-2012 | 01:18 AM
  #11105
gamedog1966's Avatar
Are you using 25 or 30 degree castor blocks on your ride? 25's will tend to do that as they have more exit steering than the 30's do...But it could be something entirely different going on with your ride.
im running the stock casters and i think they are 30 degree tho
gamedog1966 is offline
Old 02-09-2012 | 04:19 AM
  #11106
20 SMOKE's Avatar
ft truck comes with 30,rtr comes with 25
20 SMOKE is offline
Old 02-09-2012 | 04:21 AM
  #11107
20 SMOKE's Avatar
if you guy want a long buggy remember the j-concepts J82 is a T4 with a buggy body and different front tires and a few more things,fun to drive
20 SMOKE is offline
Old 02-09-2012 | 04:57 AM
  #11108
Lonestar's Avatar
I'd say "different" rather than "better", really.
Paul
Lonestar is offline
Old 02-09-2012 | 05:46 AM
  #11109
t.mathewson's Avatar
Any suggestions on a good 17.5 to run? I run the tekin rs pro esc. and I have a tekin 10.5 and 13.5. I like those combos, but i've never tried anything else soo...
Thanks.
t.mathewson is offline
Old 02-09-2012 | 06:07 AM
  #11110
kc_nitro_rc's Avatar
Thanks.
Sounds like you need a Redline 17.5
kc_nitro_rc is offline
Old 02-09-2012 | 07:07 AM
  #11111
jf+'s Avatar
jf+
Originally Posted by DaveW
What speedo?
The XP SC450BL - std on the B4.1 RTR.
jf+ is offline
Old 02-09-2012 | 07:26 AM
  #11112
916bdogg's Avatar
Originally Posted by Sampson Simpson
To anyone who is interested, PitBox Hobbies is having a clearance sale on their 8-32 Low Profile Aluminum Wheel Nuts, various colors. I believe Associated off-road cars are about the only ones left who use 8-32, so there you go.
http://www.pitboxhobbies.com/clearance.htm
You can use B44 Front wheel nutz !! Nut
916bdogg is offline
Old 02-09-2012 | 07:29 AM
  #11113
Anyone using the Lunsford "Quick tune" shock mounts? Looks like the FT blue shock bushing won't work with it, so what should I use?
GuiltyByAssoc is offline
Old 02-09-2012 | 07:50 AM
  #11114
Eric Swanson's Avatar
You will need the old plastic shock bushing. ASC #6473
Eric Swanson is offline
Old 02-09-2012 | 08:05 AM
  #11115
Think I might just have these from the old RTR...Thanks!!
