RC10B4.1 FT/WC
Good! I was so mad when I heard about the big bores because I had just spent 90 dollars upgrading to the V2's. Atleast this way all I will have to buy are the bodies!
I would think you could but by the time that these are out you would be better off just to buy these all me in a kit. you still would need caps, orings, ends and pistons.
you should've bought these when converting
http://www.amainhobbies.com/product_...ock-Body-Set-2
half the price lol.
No crush tube is used, due to the C clip used as the bearing stop
Items to do the hex conversion:
ASC9880 - Team Associated Hex Steering Block Set
ASC9881 - Team Associated Hex Front Axle Set
ASC3977 - 3/16 x 3/8 normal wheel bearings (4 pcs)
ASC6943 - 8/32 wheel nuts (I like the JCI2076 or JCI2075)
12mm hex adapters
PRO6077-00 and PRO6076-00 or JCI2081 and JCI2091 or ASC7497 (plastic)
Hex front wheels
PRO2735-02, PRO2734-04 or ASC9690, ASC9691
Hex rear wheels
PRO2736-02, PRO2736-04 or TLR7100, TLR7101
I didnt list JConcepts wheels as they are not current in stock at Amain and I haven't personally messed with the Kyosho wheels... but they should fit.
12mm hex adapters
Hex front wheels
Hex rear wheels
I actually just finished putting my Losi springs back on the car. If I'm correct, then I should turn more consistent laps and eventually put in a faster hot lap.
Remember, this is just my opinion. What I am expecting to find, based off of what everyone else has been saying, is that BB springs will make the car easier to drive faster. Nothing scientific. And I'm what you would say the Average Joe driver that spends too much time on the internet and likes to help people out, not a team guy with top notch talent.
So between Cherry and myself, you get both ends of the spectrum for talent haha.
http://www.amainhobbies.com/product_...t-Axle-Set-B41
http://www.amainhobbies.com/product_...ock-Set-SC10RS
http://www.amainhobbies.com/product_...led-Bearings-2 X2
http://www.amainhobbies.com/product_...Nut-Set-Blue-4
http://www.amainhobbies.com/product_...White-2-TLR-22
These are what I found, please add if I missed any!
Haha too late!
http://www.absolutehobbyz.com/produc...oducts_id=8713
there in stock if anyone needs one.. thank you
Just installed the Losi BB Springs on my B4.1! Did notice though that since I'm running Kyosho Shocks the Shock Collars hit the rear towers so you have to do a bit of work with a Dremmel. Just an FYI for anyone doing the same thing.
