RC10B4.1 FT/WC
yeah, I have wondered the same. Most companies are below 70c. So when some companies have magic batteries, I always wonder why reedy and others dont have magic batteries.
when the worlds car was release, they changed the front shock shafts to .80 from .71. Was this because the pros were running the .71's with the end unscrewed 2 turns? I broke a shaft this weekend and have some .71's in my pit box. Trying to debate if the .80's are really required or if I should use the .71's with less limiters. I know the shafts are only $5.49. But i have these shafts in my box that I will never use lol. I kinda wanna use them just because I have them.
They changed to te .80 shafts when the .1 came out. It was just easier to have the same complete shock as the 44 front. Plus it is more adjustability. Me and a lot of other drivers were using the .80 shafts a long long time ago instead of unscrewing the eyelet.
Ok I've done some more research and you can install them either way depending on what you are trying to accomplish. The reason I thought they might help you would be in that mogul section and you want normal pack and faster rebound so taper down.
Taper down \ | / - Slow compression, fast rebound
Taper up / | \ - Fast compression, slow rebound
a good deal
