RC10B4.1 FT/WC
Old 01-23-2012 | 10:12 AM
  #10156
Trevor Williams's Avatar
R/C Tech Elite Member
Originally Posted by ZEe_NYC
If I have to read 'big boar' one more time, I'm gonna go nutso
for real man...haha!
Trevor Williams is offline
Old 01-23-2012 | 10:13 AM
  #10157
mxracer458's Avatar
probably damn spell check on the iphones,drives me buts
mxracer458 is offline
Old 01-23-2012 | 10:15 AM
  #10158
Timmahhh's Avatar
Originally Posted by dirt_oval
I think it's more of a cosmetic thing. I use the plastic because I hate the stock blue one, and I noticed my lower bulkhead was more prone to stripping with the aluminum holder.
Is he running the aluminum bulkhead? If so, the front part is just there to cover the end of the hinge pins.
Timmahhh is offline
Old 01-23-2012 | 10:33 AM
  #10159
-WHEELMAN-'s Avatar
Most The big names here in SoCal don't run any aluminum up front to loose as much nose weight as possible. Straight from Ryan and Brent. Simple as that.
-WHEELMAN- is offline
Old 01-23-2012 | 12:35 PM
  #10160
I am in the process of installing the GHEA BB spring collars.....I am having clearance issues on the fronts making ugly contact with the tower......Im sure there is a remedy and maybe I missed it in the thread since I been active with the b4.1?? Dremel the tower seems like a easy fix but???
Please elaborate if you are using them please.
Old 01-23-2012 | 12:36 PM
  #10161
If I recall it was talked about earlier that using those collars required some spacing of the shocks out from the towers.
Kave is offline
Old 01-23-2012 | 12:50 PM
  #10162
Originally Posted by Bob Barry
Use the AE shock ends. If you get the GHEA collars (which are sexy btw) you have to shim your front shocks away from the tower a little (like .050ish) just so you don't rub.
cool.....thanks
Old 01-23-2012 | 12:55 PM
  #10163
I didn't go from ae springs to Kyosho springs. I switched completely to Kyosho shocks. I didn't notice a difference between the Kyosho and ae once I got them set for me. Only thing I noticed was that the aes leaked with the new seals and the Kyosho didn't. Old ae shocks never leaked and these didn't until I put new seals in them. I found a set of old seals left over from my rc10t3. Fixed the problem of leaking. I then switched to the Bbs and once again no difference other than they didn't let the car bottom out. I ran the car as fast with all the shocks I just liked the look of bigger shocks. and the same goes for the truck and 44 too.
Ostach24 is offline
Old 01-23-2012 | 01:07 PM
  #10164
cool.....thanks
glad I helped somone
Bob Barry is offline
Old 01-23-2012 | 01:23 PM
  #10165
F18engineguy's Avatar
I think most everyone is just taking a dremel to the the tower...you really don't have to take that much off....
Attached Thumbnails RC10B4.1 FT/WC-dsc09049.jpg
F18engineguy is offline
Old 01-23-2012 | 02:02 PM
  #10166
lip
Originally Posted by Matt Trimmings
The ball diff you would need is part number ASC9853. The b4.1 ball diff is not available in a kit to my knowledge, the b4 is but it has different sized outdrives (std bearing size, b4.1 and sc10 use metric bearings).
Is this still the case? I need to use the SC10 ball diff and this is the same as in the new b4.1 worlds car?
lip is offline
Old 01-23-2012 | 02:07 PM
  #10167
MrGidi123's Avatar
Default B4.1 Worlds Car
How come i already have the B4.1 World Car here in switzerland.. And in america it's coming out like in a month??? haha
MrGidi123 is offline
Old 01-23-2012 | 02:08 PM
  #10168
t.mathewson's Avatar
Can someone post up a link to where I can get that ghea spring collar. And what springs are yall using on it? Losi BB? Orange ft / yellow back?
t.mathewson is offline
Old 01-23-2012 | 02:11 PM
  #10169
Originally Posted by t.mathewson
Can someone post up a link to wear I can get that ghea spring collar. And what springs are yall using on it? Losi BB? Orange ft / yellow back?
info in my sig
Old 01-23-2012 | 02:12 PM
  #10170
The link was posted about 4-5 pages back I think. And yes, orange front, yellow in back
GaRsNoW is offline
