RC10B4.1 FT/WC
Old 11-26-2011, 05:50 PM
  #7846
carbons2k's Avatar
Trader Rating: 21 (92%+)
Debating if I should do the chassis mod. I have a t4 chassis I'd like to try out but seems like a pain in the ass to swap everything over lol
carbons2k is offline
Old 11-26-2011, 05:51 PM
  #7847
Kyle Wilson's Avatar
Trader Rating: 17 (100%+)
Originally Posted by TJMac
Without reading 522 pages worth of posts...has anyone stripped the blue off the aluminum to have it anodized another color?
Purple is what I'm after (daughters car).
Easy-Off oven cleaner or castrol super clean, if they still make it. I'm sure others will chime in with other methods/chemicals.
Kyle Wilson is offline
Old 11-26-2011, 06:27 PM
  #7848
Trader Rating: 50 (100%+)
Greased lighting works well too it's a degreaser you can get it at wally world (Walmart) or Dollar General
josh short is offline
Old 11-26-2011, 06:37 PM
  #7849
Yup, forgot about that stuff... Been a long month...
Old 11-26-2011, 11:37 PM
  #7850
Teambcw's Avatar
Trader Rating: 28 (100%+)
**Looking for a 17.5 motor please, if you have one please pm me, hopefully reedy sonic**
The reason I am switching is due to the fact that i drove a stock b4 and it was fun to drive even when the track got loose, had a blast.
Teambcw is offline
Old 11-27-2011, 07:31 AM
  #7851
skengines's Avatar
Trader Rating: 226 (100%+)
Any advantages from running pin vs hex rear wheels?
skengines is offline
Old 11-27-2011, 07:34 AM
  #7852
Yes, track width adjustment! With the hex setup, of course.
Old 11-27-2011, 08:02 AM
  #7853
skengines's Avatar
I was looking through pictures and it looks like a lot of the team drivers still use pin style wheels though.
Also is the inline front axle really necessary? Like I will really notice a change after putting them on?
Old 11-27-2011, 10:19 AM
  #7854
brent701's Avatar
Trader Rating: 8 (90%+)
I changed to the front inline axles and it felt way better in the turns. smoother.
Is it necessary? Not really. but it only cost about 9 bucks to upgrade to.
I like HEX in the rear. More bite I feel in the rim that a little pin.
brent701 is offline
Old 11-27-2011, 10:35 AM
  #7855
Registered User
As Brent said it is only a $9 upgrade and is a good tuning option. I did try the inline axles with the "standard" length chassis and it made the steering very sensitive and switched back to trailing axles. Give it a shot and let us know what you think
Ryno B4.1 is offline
Old 11-27-2011, 12:31 PM
  #7856
T4BongMan420's Avatar
Default overheating
hey guys whats up. I have a castle 5700 motor in my t4 with 3300mah 30c 2s lipo in it. and the motor tends to get pretty hot to the touch (not untouchable hot) after 8 minutes or so of bashing on a short grass field near my house. i have it geared 84/16 and am waiting for new 87t spurs in the mail. still heats up a bit even with that gearing. any advice on gearing or should i avoid grass for long periods of time??
T4BongMan420 is offline
Old 11-27-2011, 12:36 PM
  #7857
Off Topic:
Kyle Wilson one of the best avatar out there
lynx75 is offline
Old 11-27-2011, 01:15 PM
  #7858
skengines's Avatar
So if I want to use hex in the rear, all I will need is this?
http://www.amainhobbies.com/product_...dapter-Set-B41
Old 11-27-2011, 01:20 PM
  #7859
Asharus's Avatar
Trader Rating: 42 (100%+)
I would get the jconcepts ones, while you're at it upgrade the rollpins to the solid FT axle pins.
Asharus is offline
Old 11-27-2011, 01:55 PM
  #7860
derekbsmith's Avatar
Trader Rating: 25 (96%+)
Default servo saver bolt
How does it fit in and where exactly?
ASC9610B - Team Associated Servo Saver Bolt (Blue) (B4/T4)
derekbsmith is offline
