RC10B4.1 FT/WC
Old 11-18-2011 | 08:47 PM
  #7621
Speedy S's Avatar
Im just curious, what is the difference between a b4 and b4.1?
Speedy S is offline
Old 11-18-2011 | 08:49 PM
  #7622
About $69
Todd-ORCCC is offline
Old 11-18-2011 | 08:51 PM
  #7623
YankeeFan123's Avatar
Originally Posted by Todd-ORCCC
Thanks. Are you running silvers or browns up front? Are you running the limo chassis?
Im running the "limo" chassis with brown up front
YankeeFan123 is offline
Old 11-18-2011 | 08:52 PM
  #7624
A lot. This has been said many times before. Just go with the b4.1. end of story
Old 11-18-2011 | 08:54 PM
  #7625
Ok. Thanks
Old 11-18-2011 | 08:59 PM
  #7626
Ok. Thanks
I would still wait for someone else to answer your questions about the kyosho shocks
Old 11-18-2011 | 09:38 PM
  #7627
ANiznik's Avatar
[QUOTE=coopsnard;9930050]yea im running a 10.5. and im runing the 81 tooth spur with a 21 tooth pinion. I think thats ok right?
i would go up a few teeth on the pinion, i run a 81spur, 21pinion on a 7.5 motor in my b4.0 lol. start with a 24t pinion, and go up from there! u might end up with a 26-27t pinon with zero to little timing.
ANiznik is offline
Old 11-18-2011 | 10:39 PM
  #7628
racer1812's Avatar
Super Moderator
Dude that would be great if you could post a pic! I guess thats what im going to have to do.
Thanks fellas!
Go to 81/24, and there's no reason you should need a fan with a 10.5. Guys run 7.5's all the time with no fan. They don't run them for 30 min. at a time though.
racer1812 is offline
Old 11-18-2011 | 10:47 PM
  #7629
SoccerSting's Avatar
Originally Posted by SoccerSting
Is the difference between 20 degree caster blocks and the 30 degree caster blocks noticeable?
I'm sorry, I meant 25-30.
SoccerSting is offline
Old 11-19-2011 | 01:07 AM
  #7630
air8's Avatar
I can't even drive the car with 25 blocks on. The 30's are on and probably never coming off. That's the way to go for us mortals.
air8 is offline
Old 11-19-2011 | 01:59 AM
  #7631
ray_munday's Avatar
Thanks fellas!
That is way undergeared for a 10.5. When I run a Novak 10.5 in my buggy I run 27/72. Thats probably on the tall side for longer runs but sometimes I run it down here in Australia if the track is particularly bumpy / slippery and its as quick as my 8.5T but more consistent.
Ive attached the photo of my Kinetic setup in my B4.1 (before the +8mm conversion).
For the guys asking about whether the +8mm chassis is worth it - do it! Especially if the track is not super smooth or has jumps that arent perfectly manicured. Makes the car much more forgiving. Here is a photo from a big race 2 weeks ago I won in Melbourne using the new chassis. Thsi track was really bumpy with some huge jumps and around there it was a massive improvement! Setup sheet here if anyone interested:
http://keilorrc.org.au/setups/2011_B...ay_Coleman.pdf
Ray
Attached Thumbnails RC10B4.1 FT/WC-p1030581.jpg   RC10B4.1 FT/WC-trophies.jpg   RC10B4.1 FT/WC-b4_novak.jpg
ray_munday is offline
Old 11-19-2011 | 03:19 AM
  #7632
When using the Kyosho springs in the front for the b4.1, are they the dark yellow or light yellow springs? Thanks
I run the light yellow with standard chassis but I have seen some guys use dark yellow as well
josh short is offline
Old 11-19-2011 | 03:34 AM
  #7633
Marklas's Avatar
Just got my +8mm chassis and body.
Will test it on indoor carpet tomorrow.
Attached Thumbnails RC10B4.1 FT/WC-rrr.jpg
Marklas is offline
Old 11-19-2011 | 06:54 AM
  #7634
B4power's Avatar
Originally Posted by vfrninja
I think the only one that works is the stock proline body. You need 35-36 mm in height. I can tell you for a fact the JC Finnisher body will not fit over a MMP.
Thanks!
What body is that? MMP seems to fit fine in there.
B4power is offline
Old 11-19-2011 | 07:21 AM
  #7635
vfrninja's Avatar
Originally Posted by B4power
Thanks!
It's the proline body that comes on the FT 4.1 kit. Unsure of the name of the body. It fits the MMP perfect. The hole feeds air right across the heatsink.
vfrninja is offline
