RC10B4.1 FT/WC
#7351
in my buggy when i removed some limiters from the front shocks it helped my problem with swapping ends at the end of straights, what is happening i believe is that too much weight is being transfered to the front and makes it want to swap ends.
the other question i have is where the battery is mounted in your truck. i like 1 foam in the front and 2 in the rear.
i run inside/inside on the front and run 5 spacers inside the shocks.
the other thing to check is your wheel bearings, if they are binding it can cause the same issue.
The bearings are all new avid's. Single rubber shield. Thank you kindly.
#7352
So, First, bump steer washers are gone, then did diff fluid and it's amazing. I gained a lap. Now i'd like to settle it down just a hair more. Just a hair more stability.
AZRON, thanks for the info. Didn't mean to be rude.
I know from experience, I need more behind the wheel practice. Spend all day yesterday practicing. I like the truck much better than last time I drove. And drove it enough to actually tell a difference in how it was from last time. Same track. Same layout.
Thanks for your help folks. Is there any other reading I can do to learn about effects of changes and terms and their definitions. Heard about a Hudy book. Haven't found it yet though.
#7353
I have a 1/2 oz under rear shock tower, 1/4 oz in all 4 triangles. Had 1/2 oz next to rx as per a setup sheet I saw. but man, sure seems like alot of weight. Also, has anyone found a good piston for the shocks? The AE pistons seems to have a bit of "bleedby" I swapped my FT B4.1 shcoks on my B4 with TQ racing big bores and boy were they smooth.
#7354
Was thinking of swapping the stock body for a bulldog. Just not into the look. My biggest problem is rear end traction though.
and ball diffs are better in general but if you dont know how to properly adjust them then they can suck
hope this helps
#7355
try moving it back 1 spacer. it might help smooth it out some.
the other thing i want to ask if how many washers you have on the steering block (bump spacers) i run 2 because it smoothed out the steering alot, and seemed like it gave it more steering in the middle of the corner even while being smoother.
i have used both the bulldog and the finnisher body, and the jconcepts gave the buggy alot more steering, but because the way the rear of the body is it gave the wing alot cleaner air, so not only did if give it more steering, the use of the 6 1/2" hi clearance wing gives that combo alot of rear bite also..
imho the finnisher + hi clearance 6.5" wing (cut down to 2 or 3 lines) is alot better than my bulldog body could have ever dreamed.
#7357
#7359
whatever helps YOU do better is what you should use, if its better foryou then dont listen to other peoples criticism and critiques, thats the key to get better and then move out of that class
#7360
Ran the Finnisher on my B4 8m for the first time last night and broke my personal best by about 5sec....
They told me it would be only slightly more aggressive compared to the Punisher.
I agree...
The 8m likes the extra steering , needs it actually and makes for a lot better performance than any other body I have use to date on the new chassis...
Don't expect a harder car to drive , the Finnisher is not darty at all .
I tell you now , get the thing for your 8m and hurry up about it ....
still using Brents set-up , except .....
back shock
drill #3 piston with a #55 & 27.5W oil , green spring
2.5 pivot block , 0 degree rear hub
Very fast ....
I agree...
back shock
Very fast ....
#7361
These are what I reference:
http://users.telenet.be/elvo/
http://www.rctech.net/forum/electric...ber-links.html
http://www.rctech.net/forum/electric...they-work.html
I have the rcshox pistons in my T4.1. Kind of spendy, but I like them a lot. Hope that helps.
#7362
if you run the bulldog body, you get more steering and if you get a wing and dont cut down that much of the back then you gain rear traction. best of both worlds
hope this helps
hope this helps
Not knowing how to properly adjust the ball diffs, is exactly why I don't run one. Trying to keep it loose and simple. Trying to get better and become more consistent.
#7363
I remember turn marshalling your race
