RC10B4.1 FT/WC
Old 08-01-2011 | 05:58 PM
  #4501
Matt Trimmings's Avatar
Originally Posted by mellow
So, is there a difference with a t4 chassis and a t4.1 chassis, like there is with the b4/4.1? Seems like everyone with an extended chassis I've seen has a mold plug on the bottom.
To my knowledge it is the same, it does look like the newer plastic in t4.1 pictures though. All the team chassis look like the older stuff though. Part number is asc7440. All of the ones I have seen look like the old plastic and have the mold plug in the bottom.
Matt Trimmings is offline
Old 08-01-2011 | 06:07 PM
  #4502
mellow's Avatar
That's the answer I was looking for, thanks. Think I'm going to order up a chassis and do something similar to lowes car that was shown over on oople with little aluminum brackets instead of carbon fiber. Hopefully JConcepts releases their new body sooner than later..
mellow is offline
Old 08-01-2011 | 06:10 PM
  #4503
Jmuck69's Avatar
Do you have a link to that pic?
Jmuck69 is offline
Old 08-01-2011 | 06:12 PM
  #4504
Maybe someone that has had a t4 and a t4.1 can verify the chassis. I know that the buggy plastic was a running change but I think enough time would have elapsed to get the older chassis out of stock and the newer ones to replace them.
Old 08-01-2011 | 06:18 PM
  #4505
mellow's Avatar
http://www.oople.com/rc/photos/worlds2011/day1/
Its the Paul Worsley converted car, near middle of the page.
And Matt:
That's why I was asking in the first place, because of the b4 being changed, so maybe someone could chime in and verify. Ill probably order a chassis either way this evening.
mellow is offline
Old 08-01-2011 | 06:20 PM
  #4506
Jmuck69's Avatar
And Matt:
Thanks!
Jmuck69 is offline
Old 08-01-2011 | 06:25 PM
  #4507
That's basically how I did mine. The only difference is that I used 3mm carbon fiber instead of aluminum. I sandwiched double sided tape between the chassis and the CF. Then I screwed them together as shown with 3mm button head screws. I cut the CF with a dremel so it's not as pretty as the aluminum but it's super strong.
JW91 is offline
Old 08-01-2011 | 07:22 PM
  #4508
Waters's Avatar
I have both chassis. t4 has Molding hole t4.1 does not and the chassis has a different sheen to it. I did the chassis extension with the t4.1 chassis and used the t4 chassis for the reinforcement gussets, both chassis well used, not new by any means. I have raced my b4 now at 2 events and getting my setup closer. I like it alot and its more stable on large outdoor tracks here in Michigan.
Waters is offline
Old 08-01-2011 | 08:33 PM
  #4509
skrichter's Avatar
Where do you get the trick looking blue bleeder screws for the shocks?
+1 to who figures this out.
skrichter is offline
Old 08-01-2011 | 08:36 PM
  #4510
Well, maybe the newer t4.1 chassis' will start appearing then. I wonder if there is a benefit to having the older t4 chassis as that seems to be what was photographed at the worlds.
Old 08-01-2011 | 08:38 PM
  #4511
rednck21's Avatar
http://www.4chobbysupply.com/servlet...-Button/Detail
rednck21 is offline
Old 08-01-2011 | 08:39 PM
  #4512
http://www.fastener-express.com/2-56...e-qty-100.aspx
Mine comes with more...
Old 08-01-2011 | 08:57 PM
  #4513
Brad S.'s Avatar
My first thought - "wow matt, way to go online and find the most expensive screws I've ever seen, oh, wait..." ahahahahah
Brad S. is offline
Old 08-01-2011 | 09:24 PM
  #4514
BrentH's Avatar
I'm guessing there was a reason the team used the T4 chassis vs. the t4.1
The T4 chassis is definitely more rigid than the t4.1 There were a couple of big air jumps at the worlds. Perhaps the 4.1 had too much flex.
BrentH is offline
Old 08-01-2011 | 09:40 PM
  #4515
Wild Cherry's Avatar
Tech Legend
T-4 & B-4 plastic chassis's are the same material.
They also make graphite versions for both ...
Wild Cherry is offline
