RC10B4.1 FT/WC
#3751
I am running 17.5 buggy too im curious what more are doing for the Tekins setups and gearing. I have looked at the setups on Tekins website already but I have seen people go with standard rpm ranges and 45 timing and 10 for boost with a 35/72 but I've seen this really go all over and I think my car is a little sluggish at spots and would like to gear down more. If anyone has a good 17.5 setup can they post or pm me.
#3752
http://www.fantomracing.com/motor-setup.php
This should help you out, some of these drivers use tekin setup, i am not totally familiar with these ESC as i only use Speed Passion.
Hope this help
John
Hope this help
John
#3753
#3754
#3755
I don't know if this is the best advice for non timing, but I raced the non timing class at west coast this weekend. The only way I got my duo3 motor to work well was to keep adding teeth. By the time racing came I ended up jumping from a 35 to a 39( it was the only one I could find over a 35). Temps on the motor after 15 minutes were 155-160 and my tekin rs was about 140. Hit about 25-27 mph on the straight and felt really good on the in field as well. Running three clicks of timing and the 12.5mm high torque rigor. I want to try a 38 or 37, but those are hard to find.
#3756
After only 3 track days, my rtr mg servo is gone..(now I've got a real excuse to upgrade, Savox here I come). I know I've bashed the thing many times but still really surprised at the failure.
On a seperate note, why does the rear end "hop" after certain jumps (ususally low jumps) softer springs? 30wt in the rear should I go lower?
#3757
#3758
So I picked up a FT b4.1 the other day I am racing it on sunday in a 2wd open buggy class what I have right now for a motor is an orion 19t its nice but I have no known status of the brush quality or if I would have to cut the comm. could I run that easily or should I go pick up a 17.5 BL system for it? My driving skills should compensate for me not having a wicked hot motor in the buggy.
#3759
1.27T is stock=17.5 brushless.
2. Mod/open = whatever you can handle
if you've got a 19T some tracks may ask you to run in the mod class. i'm pretty sure that you'll find that the 19T won't be too competitive with 8.5 or 7.5 turn brushless that some might run in mod class- but then again it might haul.
you might need more like 15T or14T Double to be competitive. as you know, mod can be pretty action packed with some drivers taking in seriously if you hold them up/rub wheels or collide with them but you said your driving skills were good so that might not be a problem.
stock can be a bit more relaxed. a hobbywing or speed passion combo can be had for about $100USD or cheaper if you hunt around. any money you spend on cutting the comm (which would be a good idea) takes away from the brushless you'll eventually want/need. but if you've got the $$.
I ran a 27T in 17.5 4wd stock recently and got smoked by other drivers in speed and punch. 17.5 arrived in post and suddenly i was in the action and enjoying it!
you could grab a new 27T brushed and swap out the 19T if it turns out to be too slow. some tracks might just let you run the 19T in the stock class. it'll be fun anyway. good luck
#3760
at most/many tracks there are two buggy classes.
#3762
#3763
I need some help..
So I just bought a b4.1 and I got to the shock build and I realized that you can only build the shocks with the blessed shock cap and I was wondering if anyone has a better way to build the shocks like using a shock bladder . If you guys can help me out I would really appreciate it.
#3764
I need some help..
http://www.teamassociated.com/multim...2_Shock_Build/
#3765
They are very easy to build with the bleeder caps. Just put a dab of green slime or diff lube on the bleeder screws to make it easier to get the threads started.
