RC10B4.1 FT/WC
#4531
You just push the "hole" out of the center of the foam. Those Losi rear foams do NOT with stand much saucing tho. They break down fast. I prefer an AND 1 rear trimmed up from JConcepts. They do last longer, and stay firmer longer.
#4533
What insert do you guys usually run in your B4.1 front tires for indoor high bite clay tracks (small track, lots of 180s). I usually stuff a full Losi rear foam (from the BK Bars) but the rear tires I'm getting don't come with foams (AKA Rebars). I'm gonna use the AKA Red foams for the rear, and I'm not sure if I should just use the standard foam included with the front Rebar tires, or cut a rear AKA Red insert in half and use those.
Hey Asharus on the home track right now its not loose like the video and is med traction. I am using 3 rows with jc molded and they steer more than the 3 rows stock stuffed. Idk about critters but try those. Try hot bodies fullshots, on the last few days of lir they oversteered alot and come with rear foams. All the mod guys have them with bk rears it should work on critters also.
#4534
http://www.youtube.com/watch?v=2qhZg8MQlHw,
#4537
#4538
#4539
#4540
#4542
sucks but w.e. Don sounds really promising and ik this will work out, wanna c if I can get a job there.
