RC10B4.1 FT/WC
#3032
Do you build / rebuild your shocks at home and then go to the track to race...is the track outdoors? Sometimes the outside temp increase will cause this to happen. I will usually bleed my shocks...work them for a bit (sometimes set them in the sun to heat up if im racing outside) and then bleed them again before putting them back on the car. Not sure if this is what causes the issue but it could be...?
#3033
Just received a durango shipment of spring combinations.
Also just received a transponder system for a backyard track.
Hopefully I'll get to do some testing in the upcoming weeks (have a lot of work to do before I can run the system)
Carey
Carey
#3036
I can get you a set if you want them
I was considering it, but I still haven't used my velvets and I have several pair of v1 and v2's as it is.
Anyone want to buy some v2 or v1 shocks hit me up and I'll be willing to experiment with some big bores.
#3037
http://www.amazon.com/Velcro-Sticky-...6941439&sr=8-3
or
http://www.amazon.com/Velcro-Industr...6941439&sr=8-4
#3038
#3040
#3041
I've looked at the pro setup sheets for the car and seen that most run the zero degree rear hub carrier. The sheets don't note the rear toe blocks or rear toe-in at all. Am I missing something? Is there a standard that everyone runs? Thanks for any help.
#3044
#3045
http://www.teamassociated.com/pdf/ca..._Surf_City.pdf
is this what u mean like on the bottom of the setup page in notes it says 1/4 oz in each triangle(what u were talking about on the chassis) and 1/2 oz what does he mean behind suspension mount like behind all the battery pads??
