RC10B4.1 FT/WC
Old 06-14-2011 | 06:15 PM
  #3226
mellow's Avatar
Originally Posted by Cpt.America
Another question... its been SO long since I have worked on or built a B4... changing anti-squat? do i need a hingpin brace set, or are shims used? What part number should i be looking for?
Your kit should have came with different antisquat shims. Its really easy to change the antisquat, but the shims pop out from the brace pretty easily after a run or two.
mellow is offline
Old 06-14-2011 | 08:15 PM
  #3227
916bdogg's Avatar
Yep I put the older style ones in . I did that when I built the car a month ago .
916bdogg is offline
Old 06-14-2011 | 08:23 PM
  #3228
916bdogg's Avatar
Thumbs up AE Is Killer Of All......
Here Ya Go . $ 1.89 @ Amainhobbies.com
Attached Thumbnails RC10B4.1 FT/WC-asc9571.jpg
916bdogg is offline
Old 06-14-2011 | 08:39 PM
  #3229
I've got a bit of a different question for you guys and I apologize for asking it here but I know you guys can probably answer it. I don't have a B4 but I do have a project that may use B4 parts. I'm trying to find out what the hole spacing is on the 4 screws that hold the front bulkhead onto the chassis. What is the spacing from screw to screw going side to side and from the forward to rearward screws? Hopefully that description makes sense.
fredswain is offline
Old 06-14-2011 | 09:16 PM
  #3230
Originally Posted by idrummerboy13
check if your moter moved and your gear mesh first then your tranny
Yep, that was it! Last time it came loose, this time it went the opposite way. Dodged one there, had zero intention of opening up the tranny box..
Thnx guys!
GuiltyByAssoc is offline
Old 06-14-2011 | 09:57 PM
  #3231
Cpt.America's Avatar
Thanks.. but didn't get a kit, I got a used B4.1 and got zero parts with it... so I need my to eblocks and antisquat shims, so i bought the whole kit from amain. Good to go!
Cpt.America is offline
Old 06-14-2011 | 11:10 PM
  #3232
aeRayls's Avatar
ae made a running change to this. I just built a fresh kit and the shims arent "open" anymore so they wont fall out.
aeRayls is offline
Old 06-15-2011 | 03:30 AM
  #3233
mellow's Avatar
How long ago did they make the running change? I built my kit in March, but these damn shims wiggle out every heat race it seems. Can't complain on how easy they are to change though.
mellow is offline
Old 06-15-2011 | 07:02 AM
  #3234
I bought a FT B4.1 right after it was release, and I do believe the anti-squat shims were open. I bought a new FT SC10 two weeks ago and those were not open. I just cut out a section to make them open. Just make sure the bolts are tight and they should not come out. I have noticed sometimes those do come loose after some hard landings/cased jumps.
Jonathan Paulk is offline
Old 06-15-2011 | 09:04 AM
  #3235
idrummerboy13's Avatar
ya i just added a little ca.
idrummerboy13 is offline
Old 06-15-2011 | 09:06 AM
  #3236
916bdogg's Avatar
I just built my FT B4.1 in May and it came with the open anti-squat shims . Running Change Buy then separately .
916bdogg is offline
Old 06-15-2011 | 09:16 AM
  #3237
Default lrp sxx
what settings are you guys running on your lrp sxx stock spec. willing to try em. and on b4.1
Old 06-16-2011 | 12:54 AM
  #3238
mellow's Avatar
My chassis cracked tonight right where it mounts to the bulkhead..just on the part of the countersunk screw fitting..glad every damn place is backordered
mellow is offline
Old 06-16-2011 | 03:37 AM
  #3239
Buckaroo's Avatar
Ebay is your friend.
Buckaroo is offline
Old 06-16-2011 | 03:46 AM
  #3240
mellow's Avatar
Thanks for the suggestion, but that's the first place I looked. The only one on there is almost $40 and is located in the UK.
mellow is offline
