RC10B4.1 FT/WC
Old 11-26-2012 | 06:41 PM
  #24661
Venom1836's Avatar
Thank you.
Venom1836 is offline
Old 11-26-2012 | 07:01 PM
  #24662
Could any one tell me what 0.5 deg rear hubs do vs the 0 deg rear hubs?
A-smith is offline
Old 11-26-2012 | 07:08 PM
  #24663
Adds a .5 degree of toe without changing the wheelbase.
deftones4012 is offline
Old 11-26-2012 | 07:13 PM
  #24664
FACTORYBUTNOT's Avatar
I run at WC on high grip clay and have not tried the gear diff. My car is dialed so I don't think there is any reason to make the change.
FACTORYBUTNOT is offline
Old 11-26-2012 | 07:19 PM
  #24665
Gene158's Avatar
I'm planning on getting the worlds car kit and I'm trying to decide on a good mod motor/esc combo. I'm looking for opinions, which do you guys think I should get. I like the viper combo because of the price but not if it's going to lead to headaches down the road.
http://www.amainhobbies.com/product_...tor-Combo-105T
http://www.amainhobbies.com/product_...-ProGauge-105T
Gene158 is offline
Old 11-26-2012 | 07:26 PM
  #24666
t0p_sh0tta's Avatar
Where are you going to be running? If you're looking to jump straight into mod, then that's a reasonable motor choice. All of the nearby tracks are running a 17.5 stock class as well.
I run Tekin ESCs currently, and have nothing but great things to say about them.
edit: There's no performance difference between the RS and RS Pro in a 2WD car. Save money and go with the regular RS unless you plan on going with 4WD buggy somewhere down the road.
t0p_sh0tta is offline
Old 11-26-2012 | 07:28 PM
  #24667
rider313's Avatar
If I were to go tekin I would get the New motors and skip the old ones. The New Red can motors are serious buisness.
However I give the Overall nod to Vipers combo. It's smooth, and has more then Enough power. The progauge is a huge plus, makes at the track adjustments a breeze.
rider313 is offline
Old 11-26-2012 | 07:36 PM
  #24668
ryanpatrickgore's Avatar
viper combo looks great for the price, hear great things about it
ryanpatrickgore is offline
Old 11-26-2012 | 07:40 PM
  #24669
Gene158's Avatar
I'd mostly be running it at wolcott.
Gene158 is offline
Old 11-26-2012 | 07:42 PM
  #24670
Swaybarz's Avatar
Hey guys, ordered my big bores and was wondering what a good piston and oil combo was? Running on a med-small indoor track with fairly high grip.
Also, plan on running Novak's 13.5t in super stock and mod. What is a good starting point with gearing and possible motor timing settings to try?
Swaybarz is offline
Old 11-26-2012 | 07:46 PM
  #24671
njnewc's Avatar
I run the vtx10 in my b4, vtx1 in my 17.5 sc10, vtx10r in my mod sc10, and the copperhead combo in my 4wd sc10. I love them. Smooth powerful adjustable. The pro gauge is great for adjustments. Oh and they have a bad a$$ military discount. With that said I would go with viper. And it is the same as the tekin rs and rs pro. If u are going to run 7.5 and higher just get the vtx10. There is no need for the vtx10r unless u are going to run a real low turn motor. Hope this helps. Tim
njnewc is offline
Old 11-26-2012 | 07:52 PM
  #24672
t0p_sh0tta's Avatar
If you're going to run with us in mod, then 10.5 is mellow enough to get used to 2WD buggy with. As your skill/setup increases, then you'll want to add some boost to get it down the straight.
I'm running a mildly boosted 8.5 setup at the moment, and I'm liking the way it feels. If you ever see me up there, feel free to ask for any help, etc.
-Lamar
Old 11-26-2012 | 08:11 PM
  #24673
Gene158's Avatar
-Lamar
Alright man thanks a lot. I appreciate it.
Gene158 is offline
Old 11-26-2012 | 09:08 PM
  #24674
Go for this and just pic what ever motor you want. I suggest a 13.5 so you can run in that spec class (if one is avail) or you can boost and run mod.
http://www.amainhobbies.com/product_...ESC-w-ProGauge
Bob Barry is offline
Old 11-26-2012 | 09:32 PM
  #24675
Mxer59's Avatar
I have the big bore shocks I'm running C carbon hubs, my local track is real rough though so I was curious if the Jconcepts A,B, & C carbon hubs will work and still fit big bores? Or will the exotek hubs work with them?
Mxer59 is offline
