RC10B4.1 FT/WC
I had a pair of fronts that the screw hole was stripped out of. That was on last years car. The car I bought this year had Avid's on it so I didn't bother changing them.
I think when you switched to big bores your shocks were pressurized as much as a CO2 canister and THAT made your car barrel roll
But ya, Matt does well with it, so like everything else, different strokes for different folks.
I can't wait to see the "5 dolla foot long" that Buckland is gonna unleash on the Bumps crowd haha
Hi , need some help with setup for low bite indoor clay . currently running c hubs shaved brace with no washers , bb's standard oil and pistons with losi white and red springs . one of the locals has sugested 4.0 toe block rear which i'll try and i'll go down 2.5 front and rear oil . any suggestions for hub tower u brace combos . gold barcodes f&r . help appreciated . cheers
For those with JC hexes...I use these screws and they work perfect. Just long enough to use all the threads without exposing the screw. The stock 4mm screw provided is just stupid. No reason to not use all the threads available.
http://shop.dubro.com/p/2-5mm-x-6-so...p-screws-4-pkg
