RC10B4.1 FT/WC
Old 11-26-2012 | 09:38 PM
  #24676
Matt Trimmings's Avatar
Originally Posted by Mxer59
I have the big bore shocks I'm running C carbon hubs, my local track is real rough though so I was curious if the Jconcepts A,B, & C carbon hubs will work and still fit big bores? Or will the exotek hubs work with them?
I would recommend going to the A hub especially if you race on a rough track. Check out the AVID A/C hub towers, best of both worlds and only about $12. They are designed to work with the AE aluminum hubs, the exotek utilize a vertical ball stud and will not work with any of the towers.
Matt Trimmings is offline
Old 11-26-2012 | 10:23 PM
  #24677
Tradin Paint's Avatar
Originally Posted by Bob Barry
Go for this and just pic what ever motor you want. I suggest a 13.5 so you can run in that spec class (if one is avail) or you can boost and run mod.
http://www.amainhobbies.com/product_...ESC-w-ProGauge
I was told that there are issues running the Viper speed controls with other brand motors (something about Viper using a diferent sensor technology) I have heard great things about running the Viper combos. Make sure you stick with a Viper motor
Tradin Paint is offline
Old 11-26-2012 | 10:27 PM
  #24678
Never heard that before, I ran a VTX10 Black Edition with both a Reedy 13.5 and 17.5 and it performed great. Maybe some motors have issues and others dont??
Old 11-26-2012 | 10:41 PM
  #24679
I am good friends with the Viper USA team rep and he has said there are no issues running with other motors. In fact there are a lot of guys doing it with great success. You absolutely do not have to run Viper motors to get the speed control to work correctly.
Kave is online now
Old 11-27-2012 | 06:46 AM
  #24680
Simply not true. I run D3.5 motors from EA and they work flawlessly.
The ONLY thing I can think of is that Viper has a temp cut off setting that you can use that monitors the temp of the motor internally, rather than externally. If you use anything other than Viper motors, you could see a variance in the temp reading. And that's not even a definite. Most of us don't use that cutoff anyway. We just use the temp cut off for the ESC itself.
Bob Barry is offline
Old 11-27-2012 | 09:36 AM
  #24681
chevydc44's Avatar
Sorry for the noob question but what does the u-brace mod do and also does anybody have any pictures of the mod thanks
chevydc44 is offline
Old 11-27-2012 | 09:42 AM
  #24682
Wildcat1971's Avatar
The ubrace mod is done in conjunction with the CHub. From my experience, it helps the car rotate is little better on a higher bite surfaces. I have found on low bite surfaces that it is pretty awful. Because the rear will slid a little and square up better, it adds a little more steering on the entry of the turn and when power is applied, it will square up nicely. Again, this is mainly for higher bite tracks. IMO if your running double Dee's you probably want the A hub. If your running a Bar code, beam or suburb type of tire, the C hub and ubrace mod might be for you. Like Matt said, the avid carbon upper is nice because it is an all in one A/C hub and is cheaper than the AE C Hub.
Wildcat1971 is offline
Old 11-27-2012 | 09:46 AM
  #24683
chevydc44's Avatar
Oh ok gotcha I just here people talk about it didn't know what they were talking about but thanks for the info
Old 11-27-2012 | 10:38 AM
  #24684
Venom1836's Avatar
Double Dees and Green V1 Barcodes are both good at my local track...
Venom1836 is offline
Old 11-27-2012 | 11:08 AM
  #24685
imo, that is weird. They are a completely different tire. But I am sure it is possible.
Old 11-27-2012 | 11:22 AM
  #24686
LOL yeah that's what I was thinking too. If you can run DD's and Barcodes on the same track, that means that track surface changes ALOT lol.
Old 11-27-2012 | 11:38 AM
  #24687
Post
Ok I clarified with Viper directly. The issue is only with Speed Passion ESC and Viper motors. Below was their response.
"The only compatibility issue we have heard was Viper VST motor will not work properly with Speed Passion's new Reventon ESC. Speed Passion suggests customers to cut one of the sensor pin to bypass the temperature signal. You should be able to find that news in Speed Passion's web site.
Old 11-27-2012 | 11:40 AM
  #24688
yeah, I have seen that said on the SP thread.
Old 11-27-2012 | 12:19 PM
  #24689
RC_nooberton's Avatar
Good information Wildcat. Any idea how many ballstud washers I would have to put under the inner link to make up the difference for running the aluminum u-brace? Just to get back to the stock height?
RC_nooberton is offline
Old 11-27-2012 | 12:21 PM
  #24690
It is 2 washers to get back to the standard non sanded height, .060 is the measurement if you want an exact number.
Kave is online now
