RC10B4.1 FT/WC
Old 09-27-2012 | 08:51 PM
  #21211
RCBuddha's Avatar
R/C Tech Elite Member
Originally Posted by Matt Trimmings
its mainly used with the closed cell foams, the air needs an escape route and it wont go through closed cell foams easily. Dont recommend it with standard foams. The hole is only roughly 1/16" so your not really ruining the tires.
Originally Posted by tonyd
Here is the reason!!!!
Tape the hole shut on the rims. I wish these companies would just stop putting holes in there wheels. All they do is let dust into your foams and they start to break down and get ruined.. With having a hole in the tire instead the dirt,dust and water from cleaning get flung out of the foam.
All foams need to breathe. If you don't put a hole in the tire after you tape the rim hole closed it will just bounce like a ball if air tight.
Originally Posted by Leadfinger2011
Water drainage and air release as some inserts need the air escape routes in order to function as designed.
How many holes in the the tire do I punch? 2 or 4?
RCBuddha is offline
Old 09-27-2012 | 08:52 PM
  #21212
Rob Phillips's Avatar
Originally Posted by 5th wheel
can anyone tell me why some guys put holes in the tires.i know why holes are in the wheels.and do you put holes in the front tires on a buggy also.i dont understand this. why mess up good tires.
Centrifugal Force
Most guys will punch a small hole in the tire instead of the wheel to allow any entrapped dirt/debris/water to be flung from the wheel through the tire by centrifugal force.
Putting a hole on the inside of the wheel will cause centrifugal force to work in the opposite manner by allow dirt/debris collect inside of the wheel which will allow it to work it's way into the tire while your running.
I build my tires both ways, depends on the track conditions and the vehicle that I am gluing up the tires for. 1/8 I've always done the hole in the tire but for something like 1/10 buggy on an indoor on clay track I will just put a hole in the wheel.
Also...Typically, all tires need to be vented regardless of the type of insert.
Rob Phillips is offline
Old 09-27-2012 | 08:58 PM
  #21213
I usually do two, located opposite of each other and along the center line of the tire. I use a leather punch to make the holes, using typically the second to smallest hole (if I remember correctly).
Old 09-27-2012 | 09:02 PM
  #21214
RCBuddha's Avatar
Thanks!
RCBuddha is offline
Old 09-27-2012 | 09:07 PM
  #21215
OptimumRC's Avatar
Thanks!
A tip on buying the leather punches...Michaels sells them and they almost every week have special coupons for 40-50% off. so you can get one for ~$6.
OptimumRC is offline
Old 09-27-2012 | 09:09 PM
  #21216
RCBuddha's Avatar
Perfect, I have one close by.
RCBuddha is offline
Old 09-27-2012 | 09:26 PM
  #21217
Waflet's Avatar
Originally Posted by FlyByWire
Is this being rumored?
Hideeho
Yes, by everyone except AE
Waflet is offline
Old 09-27-2012 | 09:32 PM
  #21218
UN4RACING's Avatar
Originally Posted by Waflet
Hideeho
LMAO good one.
UN4RACING is offline
Old 09-28-2012 | 02:02 AM
  #21219
stinky cheese's Avatar
shaved rear brace.
this may have been covered before but I have seen in maifield/cav set ups they are running a shaved rear brace. any ideas on the best way to do this?
stinky cheese is offline
Old 09-28-2012 | 04:24 AM
  #21220
FLHX1550's Avatar
Originally Posted by stinky cheese
shaved rear brace.
Like this:
FLHX1550 is offline
Old 09-28-2012 | 05:00 AM
  #21221
Originally Posted by FLHX1550
Like this:
wouldn't the two little raised areas in the middle need to be shaved? or no? I'm wanting to do this mod, but, only once.
shagnat is offline
Old 09-28-2012 | 05:13 AM
  #21222
UN4RACING's Avatar
Don't shave those they are for the tranny case... Just dremel with caution take your time and shave it down as flush as possible. I used an exacto knife in a rush. And to mention I went back to the stock brace with the B option. I liked it better on our dirt and lay out. I couldn't get the shaved mod to rotate as well on our lay out. Lots of tight turns..
Old 09-28-2012 | 06:12 AM
  #21223
ryanpatrickgore's Avatar
Shaved mod should rotate better with more grip. What is your track like?
ryanpatrickgore is offline
Old 09-28-2012 | 06:49 AM
  #21224
i've never liked anything on my car except shaved / C. I'm going to try shaved 1 washer with A and then C to see if I like it but historically it always just made my car not feel right.
Bob Barry is offline
Old 09-28-2012 | 06:51 AM
  #21225
Wildcat1971's Avatar
Bob, are you running on high bite? I run on low to med traction and the C hub and shaved brace made it skate around a lot.
Wildcat1971 is offline
