RC10B4.1 FT/WC
Old 05-20-2012 | 09:22 PM
  #14986
B00t13g's Avatar
Has anyone used the losi BLACK pistons in the rear? If so, what was your setup?I'm trying out 300cst with kyosho holds and black pistons in the rear, front is staying with red pistons and 400cst with kyosho whites. The rear previously had 375 cst with reds and the kyosho golds.
B00t13g is offline
Old 05-20-2012 | 09:25 PM
  #14987
B00t13g's Avatar
Originally Posted by RC*PHREAK
34/72 a decent start point for 17.5 blinky?
I ran 72/32 with a revtech 17.5 timing was at the 3.5 notch. Motor temps were 165ish after two warm up laps and a 6 minute qual, ambient is around 85.
B00t13g is offline
Old 05-20-2012 | 09:27 PM
  #14988
bilster44's Avatar
Originally Posted by nhraman
This gear combo was money today!! (29/72) Motor temp was at 140 after a 5 minute run plus a couple hot laps. Thanks again!!
140 after 5 and a couple hot laps? I would drop down to the 28 and try it too if I were you. Try to get the motor to run a little cooler...more efficient.
bilster44 is offline
Old 05-20-2012 | 11:06 PM
  #14989
B00t13g's Avatar
Misread.
B00t13g is offline
Old 05-21-2012 | 02:36 AM
  #14990
eper's Avatar
thanks chris i planned on going up for motox but it just didnt pan out i'll definetly be there for the odonnel race are you running anything at that race?
also i'm working on shimming the top shaft in different ways to get rid of some of the side load created by tightening the slipper. if anyone else has played with this i'd be interested in hearing any findings
eper is offline
Old 05-21-2012 | 09:01 AM
  #14991
Chad Smith's Avatar
Hey guys quick question, I have had alot of promblems the last race I was at. Most of them where with the turnbuckles and ball cups. With my front ball cup it threaded it self all the way on the turnbuckle and then with the rear it did the same thing. So I replaced them with new stock ball cups and this time on the rear the ball cup unthreaded itself ending my run early.
So my question is, is there any other ball cups out there that work better than the stock ones?
Chad Smith is offline
Old 05-21-2012 | 09:06 AM
  #14992
mxracer458's Avatar
Rpm or jconcepts,or switch to kyosho ball stUds and run there ball cups,I've had to reArs shear in hAlf on me that's it
mxracer458 is offline
Old 05-21-2012 | 09:08 AM
  #14993
mxracer458's Avatar
140 is alittle cool actually,if you think it's good on power just leave it,I'm right at 153-157 after my quals on my x12 17.5.
Old 05-21-2012 | 09:14 AM
  #14994
skeasor's Avatar
Default ball diff upgrade
This may have been discussed earlier, but I couldnt find it...
Is there a kit to upgrade the b4.1 rtr from a gear diff to a ball diff?
I looked but couldnt find anything.
skeasor is offline
Old 05-21-2012 | 09:16 AM
  #14995
mxracer458's Avatar
no kit you just have to pick the stuff up separate,look o n ebay there are people selling brand new complete trannys,might be more cost efficient to do it that way
Old 05-21-2012 | 09:17 AM
  #14996
mxracer458's Avatar
for you guys running the losi 56 pistons,what are your opinions compared to the ae #2 pistons?better or worse?
Old 05-21-2012 | 09:19 AM
  #14997
skeasor's Avatar
That's what I thought. Thanks.
skeasor is offline
Old 05-21-2012 | 09:21 AM
  #14998
Though MSRP RC10B4.1 and MSRP RC10T4.1 have high prices, I think they are the best of the lot available.Their advanced features will make them the first choice for consumers.I cannot wait anymore to buy it.Thanks for the wonderful images.
erricsimmons457 is offline
Old 05-21-2012 | 09:40 AM
  #14999
kdub's Avatar
Sounds like you could have defective turnbuckles...are the threads a tight fit? There should be enough resistance to prevent them from turning in the plastic. I would call AE and ask about sending them in for replacements.
kdub is offline
Old 05-21-2012 | 09:43 AM
  #15000
For me, better. But I'm an on road racer...
jumped and landed better regardless of oil weight. IMO.
peter_robinson is offline
