RC10B4.1 FT/WC
Old 05-27-2012 | 07:14 AM
  #15136
one last question, i am going to buy the hobbywing justock 45a brushless esc and a revtech 17.5 motor and a savox sc-1257tg servo. i am using a gens ace 4000mah 30c 7.4v 2s lipo battery. the mains at my local track are about 4-5min. will my battery last for 4-5min mains?
blitz98 is offline
Old 05-27-2012 | 07:29 AM
  #15137
jf+'s Avatar
jf+
Probably four or five of them.
jf+ is offline
Old 05-27-2012 | 07:49 AM
  #15138
B00t13g's Avatar
Originally Posted by PSo
Argh, trying to search about the hex conversion. What hexes ppl use? Is it AE, JC, Proline or Avid?
Is there a problem with JC hexes, are the screws ok?
And sorry about this question again, but I really tried to find it.
Atleast I didnt want to know the differenses about FT and the Worlds kit
Get the avids for sure.
B00t13g is offline
Old 05-27-2012 | 07:54 AM
  #15139
How much more do the Avids weigh over the stock plastic? They seem like they'd be pretty heavy.
ufoDziner is offline
  #15140
thanks for the hlep guys.
blitz98 is offline
Old 05-27-2012 | 07:56 AM
  #15141
idrummerboy13's Avatar
Originally Posted by gamedog1966
im setup at 24 mm ride front/rear
gold barcodes front and rear( slicks with firm foams)
front 32.5/ orange losi springs
rear 27.5/ white losi springs
middle on front shock tower and outside on the arm
inner on rear tower and inside on the arm
inner ballstud 1mm on front shock tower
inner hole on caster
middle on rear hub and inner 0mm on u brace
i forgot that i lowered my ride height tonight at the track to 23 mm it made a small difference
you can try yellow rear springs or even a pink
white for high bite seems soft...I had that happen to me and I just went up in a spring size. Of course Im on avids, way way better then losi springs.
idrummerboy13 is offline
Old 05-27-2012 | 07:58 AM
  #15142
What can I do about the big bore springs rubbing the turn buckle in the rear. I have tried spacing it out but it seems to put the shock in a bind when I do that. I am new to the hobby about 3 months into it and have read most of this thread but dont remember seeing any thing about this.
blue t is offline
Old 05-27-2012 | 08:35 AM
  #15143
Wildcat1971's Avatar
Last night I had a Venom 5000mah 30c pack go bad. I went into the shop and bough another Venom 5000mah 30c pack. But they redesigned the case and put "feet" on the case and now it wont fit under my Carbon Fiber battery brace. I am running the original B4 FT, not a 4.1. Is my battery tray shorter than the new 4.1s? Should I dremel the "feet" off. Does anyone else have issues getting packs to fit?
Wildcat1971 is offline
Old 05-27-2012 | 08:48 AM
  #15144
mxracer458's Avatar
Unthread the threaded posts from the battery tray,just unthreAd it untill you can get blue thumb screws to tighten down on your strap
mxracer458 is offline
Old 05-27-2012 | 08:54 AM
  #15145
Wattsup23's Avatar
You just got a different venom battery not a redesigned one. The "little feet" your talking about have been on certain venom batteries for a while. To answer your question though yes you could dremel down "the feet" on the battery, or you could take that battery back and get something different. I personally don't like to dremel or modify things if I don't have to, so I would just go get a different battery with that said.
Wattsup23 is offline
Old 05-27-2012 | 08:58 AM
  #15146
polarbear72's Avatar
I don't think there's a difference between the battery trays. I'm not sure why Venum put feet under there. I run the same Venom pack n my 4.1 but it didn't come with feet. If it was me, I'd carefully grind them off with a dremel. Just don't go too far. Just go a little at a time and keep checking. Let me know how it works
polarbear72 is offline
Old 05-27-2012 | 09:30 AM
  #15147
gamedog1966's Avatar
Originally Posted by Eli
What kind of camber are yOu running? Maybe put a 1/4 turn on the turnbuckle towards the negative side.
im running -1 all around
gamedog1966 is offline
Old 05-27-2012 | 09:40 AM
  #15148
J_Bone's Avatar
Oh you can go more to help with traction rolls.
J_Bone is offline
Old 05-27-2012 | 09:41 AM
  #15149
mxracer458's Avatar
all you have to do is raise the threaded battery posts up a little bit and your golden,i ran a 5600 in my t4 and it worked fine,no need to dremel anything off.
Old 05-27-2012 | 09:46 AM
  #15150
Yeah, I raised the posts, but it wont fit under the rear battery tray lip. So i had to put it on top of the battery box in the rear. it worked and survived a few hard crashes, but it annoys me, lol.
