Kyosho Ultima SC-R Thread
#3916
I just ordered the Kyosho ultima sc-r sp and was wondering what spares I should get and keep in the tool box. Is there any hop ups I should get before building the truck? Any tips or tricks I should know about as well. Do the kit springs work or what do you suggest?
thanks
thanks
#3917
thanks
thanks
I did break a front c hub, arm and a steering rack, but that was totally my fault for clipping a pipe at like 25+mph while looki behind. Other than that truck is rock solid.
#3918
Check out my buddy Goldys Vega custom (Cut and shut Vega RB5 buggy chassis) and made this beast!
http://www.oople.com/forums/showthread.php?t=107110
#3919
#3920
You'll have to ask Goldy on oople as dont think he is on rctech.
He messaged me on FB and said it was good for s first run but needed some more drive and is tweaking his set up for the Australian clay
#3921
#3922
great truck
#3923
Hey guys I have one of tebo setups on my truck and it pushes like a mack truck, its smooth but it pushes. I'm lookin to try another setup on indoor small, technical clay track please help. I'm use to thesc10 and its aggressive steering and I wnt my k truck to steer more aggrssively and everything I do it only helps but never to where I'm use to in the ae truck
#3924
Post up your whole setup, then we can give you some things to try out.
#3925
I'm not sure about it off the top of my head since I'm not accustom with the ktruck. My ae truck I know my current setup off the top of my head. Just give me a good setup and I can keep in contact with you about which direction to go to fine tune for my taste thru pm or call on phone
#3926
It would be easier to see what you are running now, and give you suggestions to make it better, rather then giving you another set-up.
#3927
