Durango DEX210 Thread
That would be nice if the V1 base could be upgraded. Enjoying the class so far, definitely different from the 4x classes that I run.
Question on gear diff tuning...
I have the gear diff in with 3k oil now and it seems good. What I have noticed is once set in a turn I can add a lot of push with the throttle. Would going down to a 2k or even 1k oil help?
The tune feels good and I don't want to take grip away with RC changes or other tuning changes, I would like to play with the diff for now to help me hold the line from the apex out.
If I can't tune it out with diff fluid changes, I'll start working on the suspension settings.
Indoor clay med/high grip smooth.
Thanx for the input guys.
I have very good steering coming in, good steering coming out as long as I don't try to push it too much or I push. This is only a problem after the apex.
I like MX Flame's setup so far (who I bought it from) and will start messing with it but wanted to get a grip in the diff first.
I agree, changing RC takes minutes where a diff change takes 3 beers
I will be moving to RC, toe, camber and what not soon.
Thinking about it and tell me if I'm off on any of this in regards to exiting a turn...
A thinner oil will give you more turning traction in general and as said can be more prone to diffing out if traction is upset but will not push the front end as much under power (assuming power is kept in check with an accurate throttle finger feeding as much as rear traction will allow).
A thicker oil will not have as much traction in a turn but will keep a more equal power ratio to the wheels if traction is upset. The more locked in effect will push more exiting the turn (assuming the same accurate throttle finger not goosing it).
Leave fluid as is and try lengthen the rear camber link to try take a little on power traction away? Or raise the front inner link? Or both?
There are a few turns at two tracks that I just couldn't hold the line exiting and keep pace with the others, I would either be a hair slower and hold my line or same speed but exit a little wider. None of them 180° turns.
Using a stick pack now and have a shorty on the way to see if weight placement could help.
What ever you do, make 1 change at a time until or unless you feel comfortable doing multiple changes. That way you'll know what change had what effect.
Hi guys... I asked the other day because my Ultra Sportman motor got wet and it wasn't working... I managed to make it work but it didn't last too long... Now is making a strange noise, it sounds like a real engine lol, and if it's still the car won't start, if i push it a little it will start to run and with no strength like no power... Checked the battery and it seems to be good, it had 8.2V of charge...
I would like to get a cheap motor, I'm not racing whatsoever, just for bashing and jumping... Would some of the turnigy trackstar motors will be good enough for that kind of use? And the ESC, it may be broken too?? It has a nice burned smell but i had never smelled it before so i can't say it is because of running the engine in that state...
I would be really grateful of some help it didnt last me one week :/
That's why I want to get the diff figured out before I started playing with the rest.
I know it's not one thing, its the combination of many. But I kind of wanted to get the diff sorted before I started band-aiding it with other changes.
Guess I'll go down to 2k and then try 5k and get my answer from that. Then move on to suspension changes if needed once I have a feel for what I like in the diff fluid department.
A $50 motor with good reviews http://www.smc-racing.net/index.php?...egory&path=112
Stay away from the beach
Waters terrible but sand is just about as bad.
If the ESC works, it works. If it doesn't, it doesn't. If it smells toasty, not a good sign. I guess it could damage a motor if it's near failure and shorts sending trouble to your new motor. Safest to send it back for inspection or just run it and see. I would run it personally.
Thanks for the motor, wich size should i go? If i buy an ESC too, just in case cause i dont want to buy the ESC later because i need to buy from another country and would take like ages...
Another annoying question (sorry the language barrier makes difficult sometimes to find in google) The can of those motors, the turnigys and the SMC that you gave me the link, are open, will this be harmfull? I will be playing in dirt, rough dirt and asphalt...
Thanks for the help!!
The rtr ESC I believe has a 13.5t motor limit so you can't go lower (faster) than that without changing the ESC.
Hobbywing has good ESC/motor combos if you want to be safe and know that the ESC is not an issue once you get the motor. I think they have some 1/10 540 can offroad motors that are not vented to keep dirt out.
Speedpassion esc's seem to be ok though, at least send it in for repair so you have a decent backup ESC.
What size depends on what you want. Insane speed that's not easy to control, a 7.5t motor.
The motor you had with a good balance of speed and controllability is a 13.5t motor. That's probably a good choice as the gearing that's on your rtr will be at least close or maybe even right. Keep your motors around 160° or less for long life.
Thanks, i will take a look at those ESC, i think 7.5t will be awesome lol super power for play around
only $40 for a matching speed passion motor here http://www.ebay.com/itm/Speed-Passio...item1c3b671fd5
The stock ESC can take motors up to 8.5t on 2s lipo. You are fine on the ESC. Just throw in the cheap speed passion $40 motors on fleabay and have yourself a cheap basher/racer.
If I were in your shoes, I would either get another 13.5t speed passion motor or go for a bit more punch and grab a 10.5t since they are the same price.
Yes you are correct the limit is 9.5t on 2s lipo. And you can check that on Speed Passion's website here http://www.speedpassion.net/us/produ...?p=12280&c=ESC They show the motor limit for the Cirtix Stock Club Race ESC. Which should be the one that came with your RTR DEX210. A 10.5t motor or even pushing it with a 9.5t motor on that ESC would give you plenty of speed if all you wanted to do was bash and have fun jumping. If you put too much power in it and try to bash, I am sure you will be breaking stuff and without a local hobby shop, that leads to down time.
Do you think those motors are OK? I mean, the can seems like open some holes here and there, will the dirt damage it?? Or they are for off road cars...
I agree ^^ stay with the 13.5 so you don't hit things as fast. Also if you change from a 13.5 you will need to change your gearing and with not having a hobby store near you... that will be a pain ordering gears and waiting to get them.
You will need to clean out the motor more often with a vented can. You can tape the holes up, those holes help with heat so watch your temps and change gearing accordingly to stay at or below 160°.
Viper makes a sealed can motor that would work well and there are a bunch of others as well. What online store do you order from?
