Durango DEX210 Thread
#1201
Anybody know if these would work for the 210? Are these spring collars?
http://www.amainhobbies.com/product_...k-Nut-w-O-Ring
http://www.amainhobbies.com/product_...load-Nut-Set-2
and one of these...
http://www.amainhobbies.com/product_...t-O-Ring-Set-4
#1202
- I am able to absolutely mop the floor with every other buggy in high speed sweeper stability. Where my B4 would be on edge, right on the line of becoming crazy, The 210 would feel like it was being drug around the track by a huge magnet under the dirt, and can do it significantly faster.Yup, mine too.
-2 With my medium grip track, forward traction is where the fight is.... the RM4 setup is absolutely golden. Whenever I hit the gas hard, it feels like the entire car gets sucked to the groundAgreed
-3 Is anybody elses dex210 as noisy as mine? It sounds just like an 8th scale buggy.No, does this change on/off power? Describe the noise? Mine is whisper quiet
-4 I am more and more impressed with how well this thing jumps. Nothing lands anywhere NEAR as nice as the buggy does. We have this relativly large x-over double, with a decent downside. If you over jump it, both B4s and 22s will bounce, and either skid out, or flip over. Every time I did that with the 210 (hey, it happens), it would slap a little bit, but stays completely composed, and off the buggy goes. AMAZING.
-Cpt
#1203
About the noise... its a constant sound, identical to what a metal gear 8th scale buggy sounds like, only slightly less-so. My pinion to spur mesh is perfect, i even put a drop of lube on the inside of the gearbox (iv always done it on all my buggies)... and the car is NOISY!! I asked a local pro who just said it sounds like hard plastic gears inside....
#1204
#1205
hi guys,,,im picking my 210 up this thrusday ..what servo should i get for the buggy, i'm putting in a tekin rs with a 13.5 ballistic motor. i want a servo that i won't have a glitch problem with running tekin esc's. i like the savox servos but i heard when useing a tekin esc the servo glitch's ... please help ......
ps,,, randy pike can u pm me your set -up or e-mail me it at [email protected] ,,,,,thanks ,,,BRIAN
#1206
#1207
#1208
THANK YOU RANDY what servo should i get for the 210 and i mite deside to get a new servo for my 410 also . THANKS,,, BRIAN
#1212
Finally got mine all done, anyone have any issues with binding in either of the rear axle joints? I'm getting a clicking out of one side, and the height of the arm actually changes if you slowly rotate that side, almost like axle cup is bent. Haven't pulled it apart to try a different set of holes yet but wanted to check to see if anyone else had problems?
#1213
You will see pull the pin and pudh the cvd into the axle you have to push it in,it binds.
I just put my cvd in a drill took some 1000 sandpaper and removed alittle material from the ball. Problem solved. Also you can chuck the axle in the drill and clean up the ID of the axle where the cvd goes in.
Pete
#1214
#1215
Has anyone found a spur that will work without reaming it out. I was going to run a 10.5 in mine and a 26 pinion is the largest i can get to fit, so i think i will be under geared. I have tried to ream out spurs before and just have never got it to work just right. Does anyone know when some more spur gears will come out for the 210? Has anyone tried a losi 22 spur, because that is the only thing i have if i could figure out were i put the one i had i would find out for myself. Thanks
