Durango DEX210 Thread
#8701
I am very happy with the new +8 chassis and the way it makes the car handle. The car is a lot more planted through the corners and still is able to change directions just as fast as it did with the aluminum chassis. It still jumps and flies really well. I have a few more things I want to try with it and when I feel really comfortable with the car and a base setup I will post it on here.
#8702
Just thought you guys might get a kick out of this. Fit a vintage losi hydradrive slipper to the dex210 trans in rm3. Always loved the HD but brushed motors at the time couldnt really take advantage of it. Brushless should be much more entertaining.
dex210hydra_01 by phukyr, on Flickr
#8704
The car was the best it had been all day. I had some bad luck in the main and only got a couple laps in but the car was feeling pretty good. I am still doing a lot of testing and will know a lot more after this week and weekend.
#8705
What is everybody using in place of stock ball cups been having an issue with the rear inner ball cups poping off.
#8706
I haven't had any issues with the stock cups yet, but most guys are using either AE ball studs (for TC5/6) w/ RPM ends or TLR ball studs (22 series) with either Losi or RPM ball ends. Losi studs are ~1mm taller than the stock Durangos, so keep that in mind - not sure on the AE studs.
#8707
I just don't get how this is possible. I even freshened all mine up and they still pop off if u look at the car wrong. My Losi will pretty much break parts before they pop off. Most probs I've had is in practice with tons of ppl out there. But IMO its not worth the risk so I replaced them with lundford tit balls and tie rods, along with kyosho cups. So far so good. And I've taken some pretty hard hits.
#8708
R/C Tech Elite Member
#8709
i myself have had no problems with the stock cups, however, i wanted to add some bling to my ride and i outfitted it with the flo yellow jcon cups.... pimp
on associated ballstuds of course
#8710
#8711
+1 I raced my buggy for the first time last night on a large outdoor track with some big jumps and off camber landings. My ball cups we're great. I did however break a rear hub on a big crash, and even though the top of the hub snapped off, the ball cup was still attached. I did boil my cups parts tree though. Just need aluminum rear hubs now. Love this buggy!
#8712
I was looking to get a 2wd buggy. What is the difference between the rtr and kit? Did see that kit comes with ball diff and rtr comes with gear diff. Any other diffence as far as shocks or arms any stiffer? Does the kit come with tires or at least rims? Looked on website but couldn't tell. Does the rtr have a aluminum chassis? From the pics it doesn't seem to. Any info will be appreciated. Thanks.
#8713
Bought my buggy used and it had Lunsford on it no problems with them yet, on my dex410 I have the standard non hd ball cups had a hard crash Monday and broke the front arm at the hub and then got hit by a few other cars and the ball cups never popped off the studs. I think the old TD ball cups are better than the HD ones IMHO
#8714
#8715
The rtr has the DIMEC plastic +8 chassis and the kit has the aluminum, I've been hearing at my track that the rtr is grate just need a better servo and maybe radio. I like the heavier kit and IMO its body looks better than the +8 just wish they would do the old body in a +8 then I may think about going +8
