SC10 Thread
Old 03-21-2012 | 11:40 AM
  #10801
Lake Ober's Avatar
Originally Posted by tfa8rva
Does anyone run a capacitor for their steering servo, and if so, where do you get em?
Nevermind....found one. Would this work? Link
Yep, that is what you want to get... and yes I run one as well for my "power guzzling" Savox servo. Check to see if you can find one made by Spektrum. I believe they are a few bucks cheaper, and the exact same thing
Lake Ober is offline
Old 03-21-2012 | 11:41 AM
  #10802
Lake Ober's Avatar
Oh wait here it is... only $4.99
http://www.amainhobbies.com/product_...tage-Protector
Old 03-21-2012 | 11:49 AM
  #10803
Lake Ober's Avatar
Originally Posted by njnewc
I am looking to upgrade radios. I currently have a M11 with 2.4 airtronics setup. I love the radio but I want to try something else. What r u guys using and what do u suggest. Thanks
Why do you want to try something else... any certain reason? I think the M11 is about as good as it gets especially for the price. I mean, if you want something better, the Futaba 4PKS is your best bet... really responsive and very customizable. I surely don't think you would find a Spektrum radio better then the M11 though. Just my 2 cents, please don't get angry at me Spektrumers
Old 03-21-2012 | 12:07 PM
  #10804
Cain's Avatar
Tech Legend
Originally Posted by Brushless420
Looking for a good indoor carpet setup.
Springs front and rear?
Oil weight front and rear?
Toe and camber?
Swaybars front and rear?
Weight setup?
Battery position?
If I get a chance tonight or tomorrow I'll post the carpet setup I was given by one of the fast drivers at the track I go to. Just as an FYI, we are allowed to run foams but the setup appears to be common with people who don't use foams either, and its very fast on the track conditions, which are very tight with a lot of 180s, 30 x 30.
Cain is offline
Old 03-21-2012 | 01:24 PM
  #10805
for those using the losi springs.....are you using the 22 T springs in the rear? I have a set of 22 buggy springs but they are pretty short by comparison to the sc10 stock rear spring.
Quickstang is offline
Old 03-21-2012 | 01:36 PM
  #10806
Well I bought an SC10 2wd with a Velineon set-up from a member here. Going to try my hand at racing. I will ask my LHS about set-up for their track as they should know that best but I did want to see if there are any recommendations on must have parts or when I break a certain part what I should upgrade it with. It should arrive tomorrow and will post pics when I get it. Thanks guys.
SabaII is offline
Old 03-21-2012 | 02:26 PM
  #10807
CoyoteSlash's Avatar
Originally Posted by Lake Ober
WI surely don't think you would find a Spektrum radio better then the M11 though. Just my 2 cents, please don't get angry at me Spektrumers
None Taken. I know my DX3r Pro feels cheap being so light (which I love it being so light) but the computer and ergonomics are delicious.
CoyoteSlash is offline
Old 03-21-2012 | 03:56 PM
  #10808
cbaranski's Avatar
Originally Posted by mojoman81
You have pics of that ?
Ya, i do. Send me a text, there on my phone. 928-279-4293. If you want to post them go for it. I can take more that are in depth.
cbaranski is offline
Old 03-21-2012 | 03:57 PM
  #10809
Riv2SC10's Avatar
From: In the Greater Ladysmith, WI metropolitan area
You didn't mention if you had a FT version or not, or what parts yours came with, but there seem to be a few favorites for upgrading. Find out what tires are the hot ticket for your track. That'll make the biggest difference in handling. I think getting the adjustable rear arm mounts are very helpful. They're not much money, and allow you to adjust rear toe-in and antisquat. A decent metal geared servo, ball bearings in the bell cranks, and a glued servo saver are big improvements, too.
Riv2SC10 is offline
Old 03-21-2012 | 05:50 PM
  #10810
It has a waterproof Traxxas servo. It is not the FT version. Here is what the seller had in the post.
Like new AKA Wishbones - yellow wheels
Like new Proline Suburbs - white wheels
Hex Conversion
NIP TA Front A Arms - part 7446
NIP RPM Rear A Arms - part 70742
NIP Front Bulkhead - part 9563
So I just want to take make sure I have parts I might need to replace. My LHS seems to have a ton of Associated parts on hand but if there is something better I can replace whatever breaks with I want to have it in my pit box. Like I said new to racing but I don't want to look like a total noob out there. Thanks for the help guys.
~Edit~ It says RTR with some mods. It looks like it has aluminum shocks? Unless it came with them but I am not sure. Thanks.
SabaII is offline
Old 03-21-2012 | 06:19 PM
  #10811
19_mustang_96's Avatar
Red front, green rear
40wt front, 35wt rear. AE oil.
Toe and camber?
All at Zero
Both Factory rear kit, custom front.
Weight setup?
No weight
Battery position
Middle
Other
Stock front tires with kit foam, Kyosho SC with proline insert (no Tire Dope)
On my local carpet this setup is hooked up. Truck is very neutral.
19_mustang_96 is offline
Old 03-21-2012 | 06:47 PM
  #10812
primo86gt's Avatar
Default Carpet Setup. Not the flat gray onroad type carpet
Brushless420,
Coming to FL indoor FRIDAY??? My 4x4 is down right now, but buggy and sc10 are running fine.
Schumacher mini pins are the tire of choice fr & rear for SC10, rear buggy.
SC10setup red front springs , green or gray rear,
some are running as much as 60 fr & 50 rear, try 45 & 40, 1-2deg neg camber.
DON'T BE SCARED
primo86gt is offline
Old 03-21-2012 | 07:44 PM
  #10813
njnewc's Avatar
Lake, I have an addiction problem, I have had the M11 for about 3 years and I need something new. I think I will go with the MT4, I love Airtronics so that is just the logical step.
njnewc is offline
Old 03-21-2012 | 08:06 PM
  #10814
hey, airtronics is a great controller. But I agree with coyote. I love my dx3r pro. Like the look and the feel.
Eaglesrx is offline
Old 03-21-2012 | 09:47 PM
  #10815
Lake Ober's Avatar
I feel exactly the same, haha And, I agree Airtronics is the bomb-diggity, it's what I use as well. Are you considering the MT4 because of it is telemetry ability?
