SC10 Thread
Old 01-18-2012 | 12:28 PM
  #9091
I didn't know. You would think JC would have it on their site. Thanks.
jamr1130 is offline
Old 01-18-2012 | 12:36 PM
  #9092
davidfast's Avatar
It is: http://www.jconcepts.net/store/index...roducts_id=470
davidfast is offline
Old 01-18-2012 | 12:56 PM
  #9093
HighLife420's Avatar
For those of you have done the hex conversion, do you notice you gain a lot of slop?
I have check out a few people who have done the hex setup, it seems there is a TON of play between the hex and the pins, added to the play it already has, it seemed like the cons out weight the benifit. Maybe its just me...
HighLife420 is offline
Old 01-18-2012 | 01:02 PM
  #9094
20 SMOKE's Avatar
are you talking front or rear,i don't have any in mine
20 SMOKE is offline
Old 01-18-2012 | 01:04 PM
  #9095
brent701's Avatar
I don't have any slop.
When you add the shims you still keep those two little shims between the bearing and pin on the axle.
Mine are running strong. haven't even broke a axle pin for a while lol
brent701 is offline
Old 01-18-2012 | 01:13 PM
  #9096
Joliet Jake's Avatar
I have not done the conversion but will be buying parts for it tonight provided my lhs has everything in stock. My question is... my front end on my FT seems to have some normal slop in it and thats what I am wondering. Is it normal to have some wiggle in the steering itself?
Also I have been looking into replacing my servo with something upgraded. Sugestions?
Joliet Jake is offline
Old 01-18-2012 | 01:14 PM
  #9097
Cain's Avatar
Tech Legend
seems some reviews on the jconcepts hexes aren't very good.
what about the ST Racing concepts hexes?
Cain is offline
Old 01-18-2012 | 03:00 PM
  #9098
AlanHall's Avatar
Originally Posted by AlanHall
Ok.. maybe ill get a 84 and a 75 lol. My local track is 13.5 blinky
you guys think i should scratch the 75 and just get maybe the 84 and 81? from what i read most running 13.5 blinky are using a 84 spur..
AlanHall is offline
Old 01-18-2012 | 03:04 PM
  #9099
Solidd33's Avatar
'Not an expert'
I run 13.5 - 23/75 with only 6deg physical timing and it never goes over 150 even after 20min of running. Any higher on the spur and my speed would be like that of the 17.5s at my track it seems to me.
Solidd33 is offline
Old 01-18-2012 | 03:08 PM
  #9100
AlanHall's Avatar
so you would lose some bottom end in trade for top end up you ran a larger spur?
AlanHall is offline
Old 01-18-2012 | 03:10 PM
  #9101
Cain's Avatar
Tech Legend
I haven't noticed anything like that. Assuming the ratio comes out the same, the performance I have seen has been the same. the main thing I have seen is the position of the motor affecting how it handles.
Cain is offline
Old 01-18-2012 | 03:13 PM
  #9102
AlanHall's Avatar
i just want to get the right spur without ordering a bunch of them lol.
AlanHall is offline
Old 01-18-2012 | 03:15 PM
  #9103
Cain's Avatar
Tech Legend
no prob I fully understand that LOL.
heck, I was thinking of going with the inbetween spur myself, the 81T.
Cain is offline
Old 01-18-2012 | 03:18 PM
  #9104
AlanHall's Avatar
im thinking so. i may just wait. i forgot they are fully stocked at the track. probly just ask someone there.
AlanHall is offline
Old 01-18-2012 | 03:30 PM
  #9105
Solidd33's Avatar
Larger spur would make it gain bottom end/lose top end which doesn't seem ideal as 23/75 has what seems to be the same top end as the geared crazy 17.5 blinkys at my track.
In researching 13.5 no boost gearings in the past I came across: 25/75 & 19/81 for OCRC or something in Cali. Idk...
Solidd33 is offline
