SC10 Thread
#7666
17.5 no boost? run a 75t spur, start with a 26t pinion.... i usually run either a 26 or 28 tooth depending on the track, although ive started running a 28 more even on small indoor tracks. ive seen motor temps anywhere between 160-195. your goal is to have around 160 after 6 mins.
Do you notice that you have no real acceleration with this combo? I have my timing engage RPM set low (9.1k) to give myself that punch to hit a big jump after a turn or slowing down prior.
I have a 24-25-26-28 pinons to try, havent gone past 25 yet though.
#7667
Wow, im running a pretty similar setup (17.5, timing +20 degress) with a 75 spur and 25 pinon. I ran my car last night for about 10mins and my temps were barely over 110F.
I've run it at 75/28 with +15 on the can on a larger track 2 weeks ago and it felt even better. I turned the timing back to stock last time because the track was smaller and indoor, to keep temps down.
Edit: If you're at 110F, you're not gearing high enough. Stick a 26 on there and see how it goes.
#7668
Good point - i'm definitely not getting the acceleration I want but I'm still trying to get the diff set so it doesn't spin on accellerate. How big a turn do I need to make before noticing any difference on the ball diff? Does the slipper provide any help in this area?
#7669
The 17.5 classes in my area are no boost on the speedo, but you can advance timing on the motor can. Last time out I had 75/28 with the stock 30deg timing on the can and it felt great...
Was thinking of going higher on timing and gearing, but im afraid to loose what little acceleration i have now.
What are your track conditions? Are you racing on high traction surface?
I havent really messed with the ball diff, but i have the slipper tighten down to expose about 1mm of screw. Manual calls for .5mm showing, but that just spins my cluth, no pick up what so ever.
#7670
Medium to high traction
#7671
Pretty similar conditions, i run on med/high traction, smooth clay, few big jumps.
Actually thinking of trying the setup sheet from AE site. We had the ROAR Region 4 Nationals at the track i go to in Coral Springs. Have the silver springs on order, no LHS i have around me has them.
#7672
#7676
What are temps? I would go from that rather than pure speed. If you run temps are good, go higher on pinion, but remember, you sacrifice acceleration for top speed.
#7679
Are you racing or just bashing? If you racing, to me, i value acceleration over top speed. Really depends on your track though, if it has a huge straight-a-way where you can easily pass someone, then i can see it.
#7680
Can anyone plz post a link to Carpet racing set ups ?
THX
Also, I have a NIB TEKIN RS 17.5 combo For Sale
http://www.rctech.net/forum/r-c-item...combo-nib.html
THX
