SC10 Thread
Old 06-16-2011 | 07:45 PM
  #6181
Originally Posted by Asharus
I think my buddy has the same. If so, you definitely should be able to adjust the EPAs, we just did it last week when he upgraded his servo to a Savox 1258TG.
I ordered a cheap D227f off hobbypartz.com it has a .09 response time and I got the savox 1257 tg too just in case that goes, the D227f was 15$ so I figure I wont lose much and the reviews on it are not too bad.
losiracer753 is offline
Old 06-16-2011 | 07:50 PM
  #6182
Asharus's Avatar
Nice, I run the 1257 in my buggy and 1258 in my SC. I have another 1258 coming in, going into my 4x4 SC (or TC, not sure which I'm getting first).
Asharus is offline
Old 06-16-2011 | 08:02 PM
  #6183
T-BirdJunkie's Avatar
From: Norwood, OH...and CCRCR and The OhioRCFactory
I think the RS will come with V2 shocks
Originally Posted by Cameron Kellogg
The pictures I have seen of it has blue shocks on it. Maybe they will change the FT kit too and add the 12MM hubs to that too.
They are blue V2 shocks. Same stuff, cheesy anodizing.
T-BirdJunkie is offline
Old 06-16-2011 | 09:08 PM
  #6184
Cameron Kellogg's Avatar
Oh great another shock....
Cameron Kellogg is offline
Old 06-16-2011 | 11:27 PM
  #6185
So*Cal AFDude's Avatar
Originally Posted by machwon
Would the new SC10 RS be competition ready for racing? Or is that brushless set up not really competitive enough to where the only thing that is needed is driver skill?
All driver IMO. I took 1st in Expert Mod with a complete RTR out of the box my first time I raced it.... with exception of tire changes.
I still run the RTR car..ish. I swapped out for my Spektrum system, Savox SC-1258TG, Tekin Redline unsensored 5800kv, and RX8, Lunsford turnbuckles(stock ones suck), CVDs, tires of course. But the shocks, and plastics are all RTR. Running the gear diff with 7k oil. 35w oil in front and rear shocks, red springs in front, green in rear. Top 5 in A-Main for Expert Mod at most events, running against other FT cars.
I will be getting the Factory Team roller next time around however.
So*Cal AFDude is offline
Old 06-17-2011 | 09:53 AM
  #6186
chop73's Avatar
Default setup help
could you guys share your outdoor dirt track setups please!? Need help keepin up to a slash for god sakes!!?? The surface is top soil that drys out easily and turns muddy when wet. I have goose bumps and bar codes and am thinking of gettin AKA enduros!?! factory team setup in the truck now with 27.5 oil frt n rear.. tekin 17.5 and a mmp esc. no timing boost allowed. have it geared to temp out at 150ish after 4 min... straioght away speed seems good but it pushes and is loose>!>!>!> weird i know... HELP ME PLEASE...
chop73 is offline
Old 06-17-2011 | 09:58 AM
  #6187
Everyone around here seems to start with the Chad Due setup and then tweaks from there.
HeavyDuty is offline
Old 06-17-2011 | 10:33 AM
  #6188
Asharus's Avatar
I use this with the tweaks he posted, except gray springs in the back instead of green. Both for indoor clay and outdoor dirt. The only thing I switch out are tires. Green bar codes for indoor clay and green goosebump for outdoor dirt.
http://www.rctech.net/forum/9046220-post3588.html
Edit: Using 17.5 Ballistic geared at 75/26. No timing/boost.
Asharus is offline
Old 06-18-2011 | 06:50 PM
  #6189
Whats the better shock. Pro-Line Power Stroke Shocks or Associated FT V2 shocks.
J-RO is offline
Old 06-18-2011 | 06:57 PM
  #6190
Matt Howard's Avatar
I can't imagine the Pro-line shocks being better than the FT V2 shocks.
Matt Howard is offline
Old 06-18-2011 | 07:51 PM
  #6191
20 SMOKE's Avatar
pleased with my what turned out to be a test run only(track pc wouldn't work) it took a couple of runs to see how i could drive the truck its been 2yrs since i ran offroad and it was 4wd mod but very happy with the truck
20 SMOKE is offline
Old 06-19-2011 | 02:36 AM
  #6192
I had my maiden run with my FT SC10 yesterday as well. My 17.5 "blinky" time would of TQ'd open SC Yes, I do like this truck I got it pretty dialed in only using the FT weight ballast, didn't want to add the extra 3 oz if I didn't have to since I was running 17.5, gotta keep it light if possible. Ended up using Durango light red springs in the rear, they're in between an AE green and silver.
Old 06-19-2011 | 04:25 AM
  #6193
nsx_23's Avatar
I was hoping to pick up a screw kit for my truck - Is there much difference between the RCscrews and tony's kit?
Also noticed Tony's stocks a metric conversion kit - After I bought a set of Dynamite tools
nsx_23 is offline
Old 06-19-2011 | 04:49 AM
  #6194
nightc's Avatar
Can someone please tell me if the stock SC10 RTR wheels can be used for Pro-Line Gladiator 2.2" tires? I mean is it wide enough to hold the tires properly?
I plan to purchase 1 set Gladiators M3 SC 2.2" and 1 set Calibre 2.0 SC 2.2" M3.
Thanks.
nightc is offline
Old 06-19-2011 | 06:09 AM
  #6195
offtraxx's Avatar
u need short coarse specific tires. the inside of the wheel is 3" diamiter. for just a plain 2.2 wheel, t4 wheels will work but not alowed at most tracks
offtraxx is offline
