SC10 Thread
#6331
ya i know.. i was just wondering if i should just get the electronics for my roller or just buy a new one.. i can buy batteries and charger after, i wa gonna get the sidewinder sct or the sidewinder 4600kv. but if i bought the new one id have to run it as it is for now. so should i just build mine, would it be worth it or worth buying a new one instead
You could buy the RTR and sell your roller for batteries and a charger.
#6336
im running the sidewinder sv2 4600 on a smc 7.4 50c 5000mah in my sc10 and its geared at 18/87 can anyone tell me what i should run for gearing.. i ran for about 10 minutes doing high speed runs and the motor and speed control are about the same temp.. i havent checked it with a temo gun but it isnt extremely hott.. i held it for over 15 secs and it wasnt too hott to touch it.. im new to brushless so i dunno what the temps should be at.. can anyone help? i seen something on here about the gearing and i cant find it.. someone posted something about what u need to do if the motor or esc gets too hott i would like to find that
#6337
http://www.rcgearhead.com/Gearing/Browse
Ideally your temp after 8 mins should be around 150 on the motor. Go with a smaller pinion if you're temping too high (or larger spur, but you have a pretty large spur as it is).
#6338
Not familiar w/ that motor, but the closest thing I found is the CMS 36-4600? According to this, you should be geared between 87/13 or 87/14
engine to hott, gear up or down on pinion
esc to hott gear up or down on spur
something like that
yeah i have a smaller spur but my pinion is too small to work with it
#6339
Hmm I haven't seen a site like that. Maybe you're talking about this huge RC guide?
http://users.telenet.be/elvo/
But it's pretty much go with a smaller pinion or a larger spur if you want to lower motor temps
#6340
yeah thats what im talking about.. i need to know what to do.. go up or down on either spur or pinion.. i think i found it
#6344
You can't go wrong with a ball diff. Easier to dial in, but will require more maintenance. So far my diffs have been solid and haven't had to rebuild them yet. They probably have anywhere between 10-15 race days in them.
