SC10 Thread
Old 05-20-2011 | 11:01 PM
  #6001
Asharus's Avatar
Originally Posted by racer1812
that would suck, my $12 3004 futaba servos in my vintage stuff will fry an Airtronics receiver..I run all my stuff off one radio...won't ever be an Airtronics
The standard MX-3X FHSS 3 receiver can run whatever, but this FHSS 3 receiver was the only one in stock at the time at my LHS so I bought this and a servo. Besides, the servo I'm running now is lightning fast compared to my Futaba, it worked out well.
Asharus is offline
Old 05-20-2011 | 11:09 PM
  #6002
racer1812's Avatar
Super Moderator
ahh, that's fine. I'm not really up on A stuff, just not my brand. Not that it's not good stuff, just sounded like they put you in a box, which they didn't really.
racer1812 is offline
Old 05-20-2011 | 11:21 PM
  #6003
Asharus's Avatar
Yeah, I used the analog Futaba on the receiver that came with the system on my B4.1, but ended up upgrading it to a Savox 1257TG anyway because it felt so slow compared to the 1258TG I had in the SC10.
Asharus is offline
Old 05-20-2011 | 11:27 PM
  #6004
racer1812's Avatar
Super Moderator
.07 and .08, that's my kind of speed I remeber when a .15 was an upgrade...
Old 05-21-2011 | 04:55 AM
  #6005
Does anyone know what type servo will my stock associated radio/receiver handle? Recommendations?
Murray100 is offline
Old 05-21-2011 | 04:58 AM
  #6006
Originally Posted by Asharus
I went with a Futaba S3305, but when I upgraded my radio system I needed a digital servo and went with a Savox 1258TG
Did the Savox 1258 TG work with the stock Associated radio that comes with an rtr? Thanks
Old 05-21-2011 | 08:03 AM
  #6007
Asharus's Avatar
I didn't try. I hear it takes a lot of juice and may cause it to glitch. You can always stick a Novak Glitchbuster in the receiver to alleviate that problem.
Asharus is offline
Old 05-21-2011 | 09:30 PM
  #6008
Works fine in my RTR brushless.
Cravin is offline
Old 05-22-2011 | 04:06 AM
  #6009
stanleyw808's Avatar
Default Ask for Information
Dear Friends,
I would like to ask about motor heat issue in my AE SC10.
I am currently running my car with LRP SXX Version 2 with Vector X12 Stock Spec 10.5T. The Mechanical timing is set at the lowest setting (4 dots). ESC setting are Dual APC Mod "Feel" is set at lowest setting and Dual APC MOD "Boost" is disabled.
Spur Gear is 84T with 19T Pinion, following the manual suggested gear ratio.
Battery is 6.200mAh 60C.
But I kept having a motor thermal shutdown at about only 8-9 minutes of racing. Is it normal?
Is somebody can suggest me something or maybe I have something is wrong in my set-up.
Thank You very much and wish somebody could help me in someway.
stanleyw808 is offline
Old 05-22-2011 | 04:17 AM
  #6010
Thanks for the info. Any improvement in handling compared to the stock servo?
Old 05-22-2011 | 11:17 AM
  #6011
The Savox servo is definitly faster, Biggest handling improvement I made was going with the V2 shocks.
Cravin is offline
Old 05-22-2011 | 10:34 PM
  #6012
Suspended
i just lost one of the screws that goes into the rpm bumper (the really long one) anyone know a part number or were to get one
rcgarrettp9 is offline
Old 05-23-2011 | 06:00 AM
  #6013
Asharus's Avatar
According to this:
http://www3.towerhobbies.com/cgi-bin...?&I=LXYVK1&P=M
It's a 4-40 x 7/8".
Losi or Protek makes it:
http://www.amainhobbies.com/advanced...+7%2F8&x=0&y=0
Asharus is offline
Old 05-23-2011 | 01:45 PM
  #6014
Default A-Arm /Caster Block
I have a question about the caster block mounting onto the front a arm, seems there is a lot of play with the plastic spacer used .. is this ok or should I install a washer to take away the play? I'm using the FT carbon fiber front a arms.
isarctard is offline
Old 05-23-2011 | 02:56 PM
  #6015
dymndheartkilla's Avatar
Originally Posted by PhilDz
i did the rpm front a-arm mod, and it seems to be bulletproof so far. you need to get the front inner hinge pins for the gt2 though. read the tech notes on the rpm website.
tech notes say you must use the supplied bulkhead with the RPM front arms. anyone tried it with the integy aluminum bulkhead? I picked up the alum front arms and bulkhead last week but now the front of my truck dives off jumps. would like to keep alum bulkhead with RPM arms.. possible?
ALSO: anyone know where to find a wrench to use for putting the ends onto the turnbuckle? i've been using pliers and its terrible
Last edited by dymndheartkilla; 05-23-2011 at 02:57 PM. Reason: add second question
dymndheartkilla is offline
