SC10 Thread
Old 08-11-2009 | 03:16 AM
  #2176
pink_sleeve's Avatar
Am i the only one who's SC10 kit came with buggy front shock bodies instead of truck front bodies or do they all come like that
pink_sleeve is offline
Old 08-11-2009 | 06:30 AM
  #2177
GSRswapandslow's Avatar
Originally Posted by CBHVR6
so i'm new to the sc10, what are some necessary hop ups for this? Or who all makes upgrades for it?
i'm looking at the factory team titanium turnbuckles, but thats all i really found
one mine i have:
FT threaded shocks
spring kit for front and rear
FT ti turnbuckles with rpm/jconcepts ball cups
losi 1* rear hubs
ft hinge pin brace (until my rpm arms come in)
futaba s9350 servo
FT servo saver bolt
heavy duty servo saver spring
steering rack bearings
goosebumps with aka foams
losi xcelorin 13.5t sensored brushless combo
5000mah 40c smc c-max lipo
ft cvds
durbro body clip retainers
FT shock pivots
FT servo mounts
FT milled motor plate
FT clear spur cover
a bunch of spurs and pinions (a MUST)
i gotta redial in my setup with some new changes...but, it was on rails before
GSRswapandslow is offline
Old 08-11-2009 | 03:48 PM
  #2178
So nobody has an answer???
Old 08-11-2009 | 04:01 PM
  #2179
The sc10 uses the exact same shocks as the T4...rear shock bodies @1.32 inches and front @1.02. Sounds like you've gotten the short end of the stick if you have .8" or .71.
Krio is offline
Old 08-11-2009 | 04:05 PM
  #2180
That's what i was thinking. Guess i'll give AE a call. Maybe everybody should take a good look at there front shock bodies if they are running the stock blue bodies
Old 08-11-2009 | 04:40 PM
  #2181
BuggyKing's Avatar
Ya more then likely they just put wrong parts in kit. It should be 1.02 in front and 1.32 in rear. Something like that.
BuggyKing is offline
Old 08-12-2009 | 09:59 PM
  #2182
ThisDougsForU's Avatar
Well in the main tonight all of a sudden my dogbone kept popping out and it looked like it was too short. I'm guessing the rubber o ring popped out.
Anyways I guess I'll just upgrade to the MIP T4 cvds. I'm assuming those work right ?
ThisDougsForU is offline
Old 08-12-2009 | 10:05 PM
  #2183
BuggyKing's Avatar
Just make sure you have the o-rings on the outdrive and hub side. I spaced mine in the middle with like 2 o-rings on each side. I went to CVD's cause they bones wore out fast.
Old 08-13-2009 | 12:17 AM
  #2184
F N CUDA's Avatar
Make sure your down travel/droop isnt too much. Check the spacers/limiters inside the shocks to limit the length
Your rear shocks should measure about 10.5 cm center of hole to center of hole when assembled.
Fronts = 8.5 cm.
F N CUDA is offline
Old 08-13-2009 | 07:02 AM
  #2185
they work great for me....just watch for the pins trying to escape...one of mine came out and cut chuncks out of my lower a-arm!
Old 08-13-2009 | 08:32 AM
  #2186
BuggyKing's Avatar
What I do to fix that is put a piece of shrink tubing around the pin area. This way the pin doesnt slide out anymore. Works great.
Old 08-13-2009 | 10:09 AM
  #2187
F N CUDA's Avatar
Use a wrench and tighten it up.
See you friday BK.
Seriously, clean the setscrew and the hole with motor spray to remove any oil then use blue loctite and there should be no reason it would come loose, oh yeh and use a wrench.
F N CUDA is offline
Old 08-13-2009 | 12:26 PM
  #2188
tedstryker's Avatar
figured i post this in here and the track section this for all the tri-state area guys..nj..ny..ct...
dirt runners is hosting their annual dirt runners challenge like they do ever year. the track info and pre-registration could all be found in the link.. we are trying to start this year the "2wd mod corr class" all it takes is 5 people and the class will get off the ground. we already have 3 people for the class all we need is 2 more. so if your local and wanna participate in this class please come by join the fun..the track is always open for practice
http://www.dirtrunners.com/documents..._09_Slide1.JPG
tedstryker is offline
Old 08-13-2009 | 09:08 PM
  #2189
BuggyKing's Avatar
See you friday BK.
Tightening the set screw. Why didnt I think of that b4.
Old 08-13-2009 | 10:22 PM
  #2190
trdsupra88's Avatar
Well I am finally giving in and picking one up tomorrow...Is everyone diggin the gear diff? I have an extra ball diff I could throw in. Anything special to expect when building the kit?
trdsupra88 is offline
