Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
#2402
Has anyone tried "Hupo Honigl's" cactus classic setup from this years race? After reading the setup up sheet I am curious if anyone has tried it... Looks like he has the softer super soft and the front stiff.... no sway bars either... kinda got me thinking of how i used to setup my carpet sedans when I used to be good ahhaah
#2403
Just made a move and grabbed a 410r. Hope this thing is worth it.
#2404
the 14t gear is so hard to remove from the diff..
#2406
I also used this set up as my base.
You can see my slighly different set on the Durango site as well - look under "Australia" on the set-ups download page.
Cheers
Darryn
#2407
You'll love it
Before assembling the diff, try sanding/lightly grinding the shaft that goes into the 14T diff gear so it goes in nice and easy. Otherwise it will be very difficult to get it off after is is assembled.
#2408
its ok.
i tapped it out, it distorts the e-clip.
ill try it next time i rebuild the diffs... saves me replacing the clip everytime i rebuild diffs.
also i got a full set of rear springs, what do you recommend running with the stock dark blue front springs? im thinking using the light blues at the rear.
#2410
I started with Hupo's Cactus set-up as well, just moved front camber link to the inside middle (I posted my set-up a few pages back). Just start with the stock diff oils, 10k front and 5k rear is a good start point. I just went back to 10k in the front from 15k after putting in the kyosho o-rings.
#2413
His front end is a bit soft, the black springs are two rates softer than the kit dark blue. He used a short front camber link as well, probably to get more low speed steering. I based my starting setup off of this except with dark green springs in front, different diff oils, and stock length on the front camber link.
