Like Tree22Likes
Old 10-11-2010, 07:18 AM
  #2371
grapejuice's Avatar
Trader Rating: 152 (100%+)
Originally Posted by Matt Howard
Springs kinda depend on your track, I went one rate softer front and rear, dark green up front, light green in the rear. Don't use the kit diff oil in the front, way too soft. Use 7k-10k in the front and anywhere from 2k-5k in the rear.
He got the Spec kit so it has 10k and 5k oils.
grapejuice is offline
Old 10-11-2010, 07:44 AM
  #2372
Matt Howard's Avatar
didn't know they included different oils in the two kits, weird
Matt Howard is offline
Old 10-11-2010, 07:49 AM
  #2373
Corey Bernardo's Avatar
so the spec 10K and 5K oils okay then..... I also have all the tuning springs front and rear for the car
Corey Bernardo is offline
Old 10-11-2010, 07:53 AM
  #2374
R-E-A-P-E-R-'s Avatar
My kit came with the 2 different oils and they feel good in there
R-E-A-P-E-R- is offline
Old 10-11-2010, 07:59 AM
  #2375
grapejuice's Avatar
Yeah, it is weird...2k front and rear is useless...
Old 10-11-2010, 08:00 AM
  #2376
Briguy's Avatar
Trader Rating: 125 (100%+)
Does the R kit come with different oils ? I bought the R 2010 spec kit and came with 20K diff oil and 250 shock oil .
Briguy is offline
Old 10-11-2010, 08:04 AM
  #2377
TheFcuddy's Avatar
Originally Posted by rfleck
Matt, Good looking ride!
What turnbuckles, ball cups and balls are you running?
I am building my 410R as we speak. Are the stock ball cups, turnbuckles, and balls junk? How come everyone is replacing them?
TheFcuddy is offline
  #2378
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
My R came with shock oil and 1 bottle of diff oil (3k or 5K, I don't remember).
t0p_sh0tta is offline
Old 10-11-2010, 08:10 AM
  #2379
they're not junk, just a little soft. Some people have been running the stock cups with no problems. People have to replace the balls as well because they not the regular AE/losi size, they're a bit bigger. RPM makes some cups that fit the kit balls but I don't remember the part #.
Old 10-11-2010, 08:11 AM
  #2380
Briguy's Avatar
I can see changing the stock steel turnbuckles and heard the stock ball cups pop off easily . I`ll run mine the first time this week[hoping Wed. but probably Sat] and see how everything goes .
We don`t have any hug jumps and IF I stay on all fours I might use the stocks for a bit .
Briguy is offline
Old 10-11-2010, 08:17 AM
  #2381
grapejuice's Avatar
I am still running the stock ball cups with no issues, adjusting them can be hard sometimes because they pop off when turning the turnbuckle but I just put a little black grease on the threads and worked them in a little so it's easier to adjust them on the car. Plus I would rather pop a ball cup off during a race if I hit something then break it!!
The "R" kit comes with 2k diff oil....
Old 10-11-2010, 08:19 AM
  #2382
rfleck's Avatar
Trader Rating: 58 (100%+)
I bought my kit in July and it came with 250cst shock oil and 2k diff fluid. I did not use them.
rfleck is offline
Old 10-11-2010, 08:40 AM
  #2383
rfleck's Avatar
[QUOTE=Matt Howard;8055018]Lunsford turnbuckles, losi white ball cups and AE TC5 ball studs.
Hey Matt, Were you able to use one or two different lengths of the TC5 ball studs? Also were you able to use the stock lock nuts to secure the ball studs?
I am not near my car or otherwise I could probably figure it out
rfleck is offline
Old 10-11-2010, 08:58 AM
  #2384
t0p_sh0tta's Avatar
My stock cups were fine until the other day. I hit a parked car (hidden behind a marshal), and the one of the camber links refused to stay on the car from that point on.
Old 10-11-2010, 09:00 AM
  #2385
[QUOTE=rfleck;8055560]
I honestly don't remember what lengths they were. The stock locknuts will work with the TC5 ones since they're both metric and the same threads. I used Ofna gold ones to add the extra "bling"
