Tekin RX8 1/8 Scale Brushless ESC Thread
#5926
If I can get all of this straightened out!!! I also bought a CC MMM 2200, so I am not sure if I will return and exchange my 1700 for a 1900 or 2050 or just use the Mamba. I'll be there with my nitro buggy for sure. (I'm the guy with the bad shoulder that was running around marshalling 1 handed if that helps)
As far as the clutch goes... I like the feel of the clutch a little I guess. I have absolutely no self control and when you nail it with direct drive, I find the car getting squirrlely where with the clutch it seems to "soften" the power so I am in more control. (Since I am not as fast as you, it helps!!) I think the Castle comes with a pinion, so I could try it I guess....
#5927
#5928
Bummed!
So I have been racing 10th scale for a while, mainly short course. Typically place 1st or 2nd in all races entered. Only run my cars at my local track OC/RC in HB, CA. With the new expanded track, I got a Factory Team RC8B to take full advantage. Got the e-conversion kit, did a ton a research, and as a serious racer, went with Tekin ESC/Motor Combo 2050kv (vs. Castle/MMM). After a week getting it all together (purchased Tekin system from Amain for $329.99 on 12/14/09), I was finally was able to run her for the first time today!
First battery:It ran beautifully. So smooth. I was so stoked! The 2050 had more than enough pop to clear any and all jumps (even the big triple). Felt amazing!
Second battery: It ran great for about 5 minutes. Then all of the sudden, it stopped on the straight! I couldn't believe it! I read about issues, but assumed since mine was a new version (red heatsink), I dodged the bullet! Not the case unfortunately. Not even 2 cycles! And I was babying the car around the track.
Problem:
When giving throttle, simply emits a noise and motor twitches. When turned
Problem:
#5929
Problem:
Problem:
#5932
Problem:
Problem:
Let me see if I can re-create the full post:
Problem:
When giving throttle simply emits a noise and the motor just twitches. Then turned on gives OKAY chime. But once on and in neutral (after OKAY chime, but having not done anything), LED #1 blinks and #6 is dimly lit. LEDs #4 and 5 do not work period (tried scrolling through settings and they are totally not working). When I push the car and roll-start the motor, it works, but then as soon as I take it back to neutral, it stops and won't start and just makes the noise and stutters lightly.
Troubleshooting:
Did 3 hard resets. Calibrated 3 times. Used Hotlink to confirm settings (voltage cutoff, etc.). Removed sensor wire and installed a new one. Had about 3 seasoned 8th-scales guys (including HPI and AE factory team drivers) look it over. No go.
At this point, I have uninstalled the system, disconnect it completely, cleaned it and put it back (with all wires, fan and hardware) in the original packaging along with copy of the receipt. I plan on calling Tekin on Monday to start the repair/replacement process.
I am pretty disappointed. It worked beautifully (so smooth and serious power!) until it just stopped. I am sure Tekin stands behind their products. And from what I read, they seem to have the best customer support. Maybe I just got a bad apple. Who knows. I will update you all on the outcome after I talk with Tekin. Let's hope for a speedy turnaround!!! Thanks guys!
#5933
That sounds odd for sure. Too bad it's already packed up.
I'm sure we'll take care of you. Give us a call tomorrow.
#5934
Just put it back together. recalibrated acts the same. turned the motor slowly and LEDs 5, 6 & 7 show all sensors are okay. Trying to run system sensorless. What motor type # is for brushless sensorless? Or will the T8 not work as sensorless? Thanks.
#5937
Just tried motor type #7 and #1 again without sensor wire and it worked. However, seems LED #4 is still not working. #5 is working sometimes. And when I try and set VC, MT and NW, etc most LEDs are not working, so it's hard to tell what setting it's on. Just tried running again with sensor wire installed and it cogged on startup. But once it got going, it spooled up. Still delays on throttle really bad. Tried with new sensor wire and still acted same way. Seems it not the sensor wire or the motor sensors. Looks like something internally with ESC with sensored operation and NW. Anything to fix or is it a repair/replace job? Thank you.
#5938
Sounds exactly like a issue I had with a rs pro not to long ago. Brand new right out of the box something was wrong in the esc with the sensors. Worked fine without the sensor wires but as soon as I plugged in the sensor harness it stutered on the start up. I sent it in and they had a new one back to me right away. The whole thing took maybe a week total. I'm sure you will get taken care of quickly.
Btw... this isn't one of the "usual" issues. Sounds like you just got lucky. Lol.
#5939
#5940
Just an update: already got a reply from my email to Tekin (from Randy). Seems they are on top of things there (heck, it's Sunday!). I'm very impressed. Seems what I read was right! Solid service. Seems I made right call going with Tekin. Since electric 8-scale is so new and all manufacturers are still working little bugs out, it's nice to know these guys are working hard to make things right. More as it develops...
