Tekin RX8 1/8 Scale Brushless ESC Thread
#5611
Cory B,
Rotate the motor 90 degrees and the 4mm screws provided with the 8e 2.0 will fit. the can has both 3mm and 4mm holes.
The speedo should have enoug wire to connect the motor and batteries based on the wiring needed to get a losi setup.
The Hot wire is an accessory. It is not included with the speedo as everything it does except for a custom LVC can be done using the buttons on the unit.
#5612
Couple of questions; The Hotbodies manual tells you to deactivate the electronic brakes, so do you do this by turning down the BS and DB? I'm mixing the third channel for brakes.
Does the fan run full time or on demand?
What is the latest RX8 firmware, 198? I have the Vegas software on my Hotwire for my on-road toys.
#5613
Hi there. I am in the process of building a Losi 8ight 2.0 and converting it to electric. I chose to buy the race roller instead of the Losi 8ight-E is because I wanted to get the Tekin RX8/T8 from the start.
My question is.....when I opened the box, there were no instructions included. I have been to the Tekin website and found a manual there, so that was helpful, but what size screw does the motor take to mount it to the motor mount? The Losi electric conversion kit comes with screws, but they dont fit and I think they are made for the Xcelorin motor. also. My Tekin didnt come with any wires to make a battery connection, just wires to solder the motor to the esc. Is it supposed to include battery wires?
and just one other thing. How am I supposed to hook this thing up to my PC to utilize the hotwire program? Nothing was included for that either.
While I am happy with my Tekin purchase, I am fairly dissapointed that it didnt include instructions, battery wires, motor screws or a hotwire adapter. One would think that if they spent $330 on a motor/esc combo, those items would be included
Oh, and one other question. what is the best way to secure the esc to the supplied battery tray that is included in the Losi conversion kit? There are pre-drilled holes, but it is designed to fit the Xcelorin esc. Thanks in advance.
#5617
Hi Randy, I took the plunge into 1/8 buggy and picked up the RX8 and 1900KV motor. The chassis is a Hotbodies Ve8 and I will be using the mechanical brakes.
#5619
200 will load into the rx8 but you will see no performance gain.
#5622
I am ready to buy a RX8/T8 2250kv T version (2320), but I want the red heat sink. I have asked several vendors, but they still have the black versions.
Can someone tell me where I can pick up a red version online from a US vendor other than sleezebay?
Tower is out of stock
Amain is black
Stormer is black
Waiting on others....
Amain is black
Stormer is black
#5624
Amain is black
Stormer is black
Amain is black
Stormer is black
#5625
I heard the ones with the red were newer and had less issues with them. True or not, I am not worried about it now and ordered one. I know Tekin will make good if I do have issues.
