Tekin RX8 1/8 Scale Brushless ESC Thread
Hey all,
I dropped an Rx8 in my SCTE with a Revtech 4800 4 pole. Im running Ty's setup with a 14 T pinion.
my question is for some reason the battery went below voltage cutoff and puffed my lipo. After the run i checked the volatge on the lipo and both cells went below the 2S setting.
is there anything i can check my lipo cutoff settings or any troubleshooting i can do?
Hey all,
Lipo cutoff is off by default. Did you change it to 2s before you ran it?
Do you happen to have the Hotwire? If so you can set a manual cutoff higher than the default, that's what I do. I think the setting I chose is something like 3.64 or thereabouts...
Hey all,
What batteries?
Anyone have a good setup for boosting a 4 pole motor??
4 pole motors don't boost very well. I would suggest staying below 30 on the timing advance slider with the default start/end rpm's. I run my 4 pole motors at 10 and gear up if I need more power as this produces less heat than adding timing.
[QUOTE=edlee;10639646]Hey randy. I got a RX8 T8 1900kv motor in a rc8be with a 18 pinion and a 46 spur running a 4s 5000 mah pack, from what I have read its an appropriate gearing. I'm getting some awfully high temperature readings on my esc, all 7 leds and sometimes just led7 comes on. I also eventually lose all my reverse, the RX8 still receives the signal but nothing happens. When I let the RX8 cool down to suitable temperatures it works like a charm. Hope you can shine some light into this.
thanks,ed[/QUOTE5
thanks,ed[/QUOTE5
