Tamiya DB-01 Durga. The next budget racer?
#722
I think every off road car tyres wobbles even being new.
most of the rims aren't perfectly rounded
#723
another question...
i'm running brushless... hobbywing 120A esc with a ztw 8.5T.
At first, I ran it with the 17T pinion... after a 3 min run, found motor to be hot... no temp gun, but seasoned finger-testing tells me its around 90 degrees C. LIPO was also warmer than usual... close to being hot... and of course, it bloated and is now ruined (lucky it was an old battery).
so i guess i'm under geared? yes?
at 17T, FDR of 11 (according to the manual).
I have a 19T pinion in the car now, but yet to run it. a 19T will give me an FDR of 9.85.
Thoughts anyone?
#724
I always take "Novak's brushless gearing advice" as a starting point.
http://www.teamnovak.com/tech_info/b...r_gearing.html
for a 8.5T on a 4wd buggy says a FDR of 9 so you will need a 20-21 pinion.
Even that the best tuning tool it's a thermomether. Do yourself a favor and buy one. It's cheap (10-20$) but a lot useful.
I use a 120 xerun v2.0 on my durga with SP v3 6.5 T and the firmware of the ESC had a major impact on temperature. Try *205g or *205MOD. firmware ( you can upgrade firmware with the lcd program box and a PC).
If the temperature problem persist, check slipper (maybe too thigt), and/or decrease timing.
Hope this helps
Hope this helps
#725
Hope this helps
Hope this helps
Just out of curiosity... have you tried 'converting' the rears so that it can take hex wheels?
Yeah Racing makes 'adapters' for the db01, and was just wondering whether it was worth putting them on. Main reason for wanting to do so is because I also have a Kyosho RB5 SP, and it would be good if the wheels (rear) could be used on the Tamiya as well.
Will putting the hex adapters change the handling characteristics of the db01 in any way?
#726
No, I didin't try it, because when I bougth my durga, I had a B4.
Now I drive a TeamC TC02, and because I store a ton of B4 rear wheels, I directly change the rear axle of my TC02 to fit.
You can try this: Put the original wheels, and with a measure tape, check the rear width.
Now, take the hex of your RB5, and put on the durga axes (direct fif, I hope), and mount RB5 wheels, and recheck rear width.
If it's the same, you can use kyosho wheels on the durga.
One more tip: Cut the front part of the rear wing, so this don't mount on the rear shock tower. This will increase the durability og this part
#727
The tip re the wing will save me a bit of $
#728
For sale brand new Tamiya TRF Buggy Dampers Item #54028
http://www.rctech.net/forum/r-c-item...ars-parts.html
#729
Hi there,
I was wondering if anyone would be able to help.
I m trying to find somewhere that sells the K parts tree for DB01.
The parts I m after in particular are the K1 parts. Somehow I managed to strip a few of the teeth on it so now my rear diff sits crooked.
Thanks!
Thanks!
#730
Hey there,
Not sure where you are located but if in the US but they will have them at Tamiya's US site.
If in the UK
http://www.fusionhobbies.com/Tamiya-.../ta9115204.htm
http://www.timetunnelmodels.co.uk/li...ducts_id/22079
http://www.tamiyaparts.co.uk/live/ca...ducts_id/22079
TamiyaUSA does not ship outside of the US but fusion hobbies is world wide believe.
Not sure why almost all the places that happen to have these seem to be located in the UK but thats what I was able to find.
If in the UK
#731
If anyone happens to be looking for a durga over the next 2 days - pass on it and get the Race spec version of it - DB01R
If your Canadian (lol) you will probably never see a buggy this good a price like this
http://www.muchhobby.com/shopping/pr...oducts_id=4282
This sale is till Dec 31st.
from $349.00 reduced to $199.00
Just an FYI
Just an FYI
#732
http://www.teamtrf.com/index.php/com...-racer-rewards
Tamiya Racer Rewards
The Tamiya Racing Factory (TRF) has a long history of championship winning vehicles with great drivers behind them. With less than a year of racing under its belt, our new TRF201 buggy has already taken the 2010 2WD Off-road European Championship. In addition, Tamiya also won the 2010 4WD Off-road European Championship with the TRF511. With much fanfare among off-road racers, the TRF502X was recently introduced with 2011 in its sights.
We’re hunting for more victories in 2011 with our 2WD and 4WD TRF buggies. Tamiya America would like to show its support to our racers by offering a reward program to our loyal customers, as well team drivers. This new program is valid for both racing venues listed below:
2011 Reedy International Offroad Race of Champions Jan. 27th – 30th, 2011:
* 4WD Open Class
o 1st Place - $500.00
o 2nd Place - $300.00
o 3rd Place - $200.00
* 2WD Open Class
2011 ROAR Offroad Nationals Aug. 11th – 14th, 2011:
* 4WD Open Class
* 2WD Open Class
* 2WD Stock Class
Tamiya America would like to wish you the best of luck at these races and all the races in 2011. We look forward to a great showing from everyone and their Tamiya kits!
* Federal and State tax laws will apply to contingency awards. Tax forms must be completed before award(s) can be paid.
* 4WD Open Class
* 2WD Open Class
* 4WD Open Class
* 2WD Open Class
* 2WD Stock Class
#733
#734
I just picked up a DB01R and was wondering if anyone had any tips or anything. My major recommendation to anyone is to get the rc screws stainless steel screw kit. Makes assembly a lot less painful (literally and figuratively).
So far the car seems like it will balance out nicely. As far as I can tell the left/right balance is almost spot on and probably won't require any weight. The front/rear balance seems a little tail heavy, but I can't tell yet as I am not done with assembly.
Electronics I'm using:
Tenergy 5000mah 7.4V 25c hard case pack (same as racers edge)
LRP SXX TC-Spec V2
Team Orion 4.5T
Spektrum SR6040 high speed steering servo
Spektrum Pro SR 3000 receiver
AMB/MyLaps V4 transponder
LRP SXX TC-Spec V2
Team Orion 4.5T
#735
Rear outboard ball connector rubbing
Hi. Was wondering if any of you have any problems with the DB-01's rear ball connector rubbing the inner edge of the wheel at full droop? It seems rather odd that such a problem would even exist even though most of the time it doesn't really matter except when the car is in the air.
I am running a DB-01R with the TRF shocks (shimmed to limit droop and prevent the drive shafts from dropping out).
Any insight would be much appreciated.
