Tamiya DB-01 Durga. The next budget racer?
#691
Cheers.
#693
#694
Cool thanks for that, exactly wat i was looking for. One more thing. Does the DB01R come with hex screws?
Thanks.
Thanks.
#695
i have them installed on my car. but the stock wheels wont fit. so you can look for other aftermarket wheels which is more cool
#696
Ah sorry i meant the actual screw in the kit, are they hex type or philips?
#697
Well it's been 2 months since I have upgraded the chassis, motor mount and a heat sink. The motor will not go over 130 degrees, the heat sink on the chassis gets nice and hot and it does the job, I assume the Tamiya upgraded motor mount is also doing it's job. I was dealing with the heat issue for quite some time but not no more
rnd_tang, they use the philips screws.
#698
Cool thanks! I ll order some hex ones. Cheers.
#699
#701
Finally got my DB01R up and running, one problem though.
The steering binds when I turn full lock either direction, one side is worse than the other. It seems that it is turning too much and going past a particular point so when the servo goes to centre, the binding side will abruptly flick back to centre.
If I m turning full lock right, it is the right wheel that will bind (looks like somewhere around the steering arm ball joint) and flick. Same deal with turning full lock left.
Anyone have this problem? Fixes?
Thanks!
Thanks!
#702
Thanks!
Thanks!
#703
Yah, that part is fine, nothing touching at all.
I fixed it by setting the EPA, I guess I just had to sacrifice some of the steering.
Would you happen to know what kind of turning circle diameter should I be looking to set my car to?
Thanks.
Thanks.
#704
Try 1/4 turn less
#705
Awesome, I'll give that a go. It's not so bad when you're actually moving coz the car going forward kinda pushes it back into place without too much of a jolt, its more when the car is stationary.
