New ACADEMY 1/10 scale 2WD BUGGY >
Old 10-13-2007, 05:44 PM
  #451
gndprx's Avatar
Trader Rating: 18 (100%+)
Awesome on the front axles guys, thank you. The shop where I race is flooded with Associated parts, so that makes it easier to do a switch.
I'll have to put some serious thought into this for next season or maybe for the new indoor track opening up by us. We still race outdoor all winter so I'd have plenty of time to play with it and get a feel for tuning.
Thanks.
gndprx is offline
Old 10-13-2007, 05:52 PM
  #452
Jeremy Blair's Avatar
Trader Rating: 23 (100%+)
Default water
They are spraying HIGH QUALITY H2O AKA water. they soak it at night and its great in the morning. When its raining the moister stays in the track and you can run slicks. Its Dialed.
later Jeremy
OH Dave G you got a PM.
Jeremy Blair is offline
Old 10-13-2007, 06:23 PM
  #453
Well, got a 3 a 4 and 2 in the last qual. missed TQ by 2 10ths int he last round of the day. Been tuning on the car all day...really have learned a lot. Getting better and better. Make a pretty big breakthrough in the last qualifier.
One qualifier to go then the mains...looks like I will be starting 3rd.
2wd mod....After 3 rounds
1. Rod Rippie - B4
2. Mack Vanderbeek - B4
3. David Alberico - GV2
4. Chad Parks - B4
5. Chris Baumgartner - RB5
David Alberico is offline
Old 10-13-2007, 07:47 PM
  #454
Default GO DAVE
GO DAVE TEAM MRC see you in the morning.
later Jeremy
Old 10-13-2007, 07:52 PM
  #455
nc-hopsing's Avatar
Go David, way to put a good showing in for the new car!
nc-hopsing is offline
Old 10-14-2007, 06:57 AM
  #456
WOWfactory's Avatar
Smile 1
Hello! Guys~ ^^ Nice to meet you.
Today I bring some new images about GV2.
These are boxart, two type of pattern bodys... or something like that.
My brother got it the day before yesterday. It was a good deal.
The pro kit has color manual, 2pair of wheel&tire, so many purple parts, available to Pro-Line type(front, rear), some of spurgears(6) and extra parts
Academy 2WD Buggy GV2
Specifications
WIDTH : 248mm
INTERNAL GEAR RATIO : 2.42 :1
FRONT CASTER : 25 / 27.5 / 30
REAR TOE-IN : 3˚
ANTI-SQUAT : 2
WHEEL BASE : 270mm
■ HIGH COMPATIBILITY WITH AFTERMARKET WHEELS[FRONT/REAR]
■ BALL DIFF
■ FULL BALL BEARING[20EA]
■ AL FRONT ARM MOUNT[27.5]
■ U-DRIVE SHAFT
■ AL REAR ARM MOUNT[TOE : 3 / CASTER : 2]
■ AL REAR WHEEL HUB
■ DOUBLE TYPE SLIPPER CLUTCH SYSTEM
■ TURNBUCKLE ROD
■ DIAL TYPE AL DAMPER
■ MLP SYSTEM[MULTI-LENGTH PIVOT SYSTEM]
Attached Thumbnails New ACADEMY 1/10 scale 2WD BUGGY-gv2-1-boxart1.jpg   New ACADEMY 1/10 scale 2WD BUGGY-gv2-2.jpg   New ACADEMY 1/10 scale 2WD BUGGY-gv2-3.jpg   New ACADEMY 1/10 scale 2WD BUGGY-gv2-4.jpg   New ACADEMY 1/10 scale 2WD BUGGY-gv2-5.jpg
WOWfactory is offline
Old 10-14-2007, 09:02 AM
  #457
mfishel's Avatar
The body is growing on me. And this is one fine looking machine.
mfishel is offline
Old 10-14-2007, 09:35 AM
  #458
Tony Newland's Avatar
Trader Rating: 53 (100%+)
Cool, I was wondering if it was fruit punch or something, we sometimes do that to run slicks, the rest of the time its clay panthers or pink tapers
Tony Newland is offline
Old 10-14-2007, 10:16 AM
  #459
Davidka's Avatar
Trader Rating: 86 (100%+)
I'm looking forward to see the setup David A. arrived at. The tracks I race on are very similar to the one he's racing on this weekend. Of course, I'm looking forward to getting the car too.
Dave G. great job on this car, how long now? I'm giddy like a school kid to get this thing!
Davidka is offline
Old 10-14-2007, 04:47 PM
  #460
Default us too
Tony- Yeah when it does dry out its pink tapers or switches here to just depends on mother nature. If its cool or rainy its slicks if its dry then back to tapers. The car looked real good on slicks or tapers. We were runing tapers Friday for practice becasue it was humid and dry. Saturday was raining.
Congrats on the new deal man.
later Jeremy
Old 10-14-2007, 05:30 PM
  #461
Thanks for the info Jeremy, that is an exact duplicate of our track...David's setup should be good here.
I'm pumped, cant wait to get the car!
Old 10-14-2007, 07:55 PM
  #462
It was a good weekend. The 2wd mod mains came down to the final main. In the final of 3 it was between myself and 2 other drivers to win. I had a chance but as the track dried out it was back to pin tires and I made a bad tire choice and chose panther tires instead of pinks tapers...had a bit too much rear bite. At the end of the main we were about 1/2 of a straight-away apart. I came up with 2 setups. One a basic setup, this is what I would recommend starting with. Another I had with slicks on, I ran this setup in the final main with treads, it will make the car more aggressive. With the tracktion and slicks I thought the car was awesome. I tried a lot of things this weekend, including some Losi springs, anti-squat, various camber locations...etc.
I can honestly say, this car is just as fast as anything else, and it is right out of the box, no plastic chassis to buy or anything like that...I even ended up with the same springs the come in the kit.
Here are the results from this weekend... top 5...all I can remember
2wd mod
1. Chris Baumgartner - Kyosho RB5
2. Mack Vanderbeek - AE B4
3. David Alberico - Academy - GV2
4. Rod Rippee - AE B4
5. Chad Parks - AE B4
Basic Setup...
Front
camber 3 - C 2 #4 washers under the ballstud
steering - stock rack with one #4 washer on the spindle
MLP - narrow
Shocks - 1 hole academy pistons, 27.5 Losi oil - white spring
shock at middle hole in arm, middle in tower
27.5 aluminum caster kickup
Rear
stock 2 degree's of anti-squat
camber 2 - B no washers
shocks no limiting ( may look like a lot of droop) 25wt losi oil, academy 2 hole pistons white springs
shocks mounted middle in arm and #3 in tower
MLP narrow
tires - 7206P's and 7273P.
Slicks's setup....
Front
camber 3 -C 2 #4 washers
steering rack with one #4 washer under spindle
front shocks .30 limiting 27.5 losi oil, white spring
shock on inside hole in arm middle hole in tower
30 degree caster block
MLP wide
Rear
2 deg anti-squat
camber 2 - A(hub) no washers
MLP - narrow
shocks 27.5, 2 hole pistons white springs
shocks middle in arm #2 in tower
Here are some pic of the car and track....
Attached Thumbnails New ACADEMY 1/10 scale 2WD BUGGY-chillicothe-001.jpg   New ACADEMY 1/10 scale 2WD BUGGY-chillicothe-002.jpg   New ACADEMY 1/10 scale 2WD BUGGY-chillicothe-003.jpg   New ACADEMY 1/10 scale 2WD BUGGY-chillicothe-004.jpg
Old 10-14-2007, 09:00 PM
  #463
Default good job
Good Job Dave the car looked great. I just wish my radio wouldn't have fallen.
later Jeremy
Old 10-14-2007, 10:06 PM
  #464
T. Mertz's Avatar
Good job Dave, way to show how good this car really is! Do you know if this dirt you were racing on was similair to the dirt at CRCRC? Im planning on going there again in Jan. and I was gonna try your setup. Thanks.
T. Mertz is offline
Old 10-15-2007, 06:16 AM
  #465
beeanner's Avatar
Trader Rating: 89 (100%+)
Good job Dave! Nice showing for the GV2 this weekend!!
beeanner is offline
