New ACADEMY 1/10 scale 2WD BUGGY
#466
A few other things to note, I saw some comments earlier about the wing mount. This is actually an awesome design, easy to take off, and the mounts flex in just the right way so you don't break a wing or the mount, but strong to keep the wing steady.....serveral racers really liked this when looking at the car up close.
I ran some tires I had mounted on A/E wheels. The fit is really good. Depending on your wheel and bearings your might need a couple of motor shims to get the adjustment correct...again depends on the bearings and the wheel you use. I used one shim on each side. The off-set for the A/E wheels compared to the Academy wheels are the same, so you don't need to worry about that.
I put probably 20-25 runs on the car and some were 8+ min practice runs. and the outdrive still look like they show no wear and this is a track where you could do wheelies on demand. The car is still perfectly tight, no slop from any plastic.
#468
Hello! Guys~ ^^ Nice to meet you.
Today I bring some new images about GV2.
These are boxart, two type of pattern bodys... or something like that.
My brother got it the day before yesterday. It was a good deal.
The pro kit has color manual, 2pair of wheel&tire, so many purple parts, available to Pro-Line type(front, rear), some of spurgears(6) and extra parts
Academy 2WD Buggy GV2
Specifications
WIDTH : 248mm
INTERNAL GEAR RATIO : 2.42 :1
FRONT CASTER : 25 / 27.5 / 30
REAR TOE-IN : 3˚
ANTI-SQUAT : 2
WHEEL BASE : 270mm
■ HIGH COMPATIBILITY WITH AFTERMARKET WHEELS[FRONT/REAR]
■ BALL DIFF
■ FULL BALL BEARING[20EA]
■ AL FRONT ARM MOUNT[27.5]
■ U-DRIVE SHAFT
■ AL REAR ARM MOUNT[TOE : 3 / CASTER : 2]
■ AL REAR WHEEL HUB
■ DOUBLE TYPE SLIPPER CLUTCH SYSTEM
■ TURNBUCKLE ROD
■ DIAL TYPE AL DAMPER
■ MLP SYSTEM[MULTI-LENGTH PIVOT SYSTEM]
Specifications
WIDTH : 248mm
REAR TOE-IN : 3˚
ANTI-SQUAT : 2
WHEEL BASE : 270mm
■ BALL DIFF
■ U-DRIVE SHAFT
■ AL REAR WHEEL HUB
■ TURNBUCKLE ROD
I just realized this says his brother got it a couple of days ago Was this released over seas already? Box art looks nice. So, whats the deal Dave.....
#471
Good racing at Chilli again Dave. The car definitely looked good. It was cool to see the Academy and Kyosho cars able to hang with the B4.
#472
I think one of the coolest things about Dave Alberico and the GV2 this past weekend is that we sent him 1 complete car with "0" spare parts what so ever. He started running it on Thursday, ran it all the way up until Sunday and didnt break ANYTHING! Hats off to Dave for an excellent run this past weekend!!!
http://www.amainhobbies.com/product_...ducts_id/16974
Whos in???
Whos in???
#475
Ok cool, thanks Jeremy.
#477
On Friday (practice) our group of 8 guys broke 31 arms... almost all right fronts. That's from being aggressive learning the track. I broke 3 times on the same corner until I finally changed my line there. Saturday-Sunday we stopped the bleeding mostly.
So Dave had to be very disciplined in his driving to get through the weekend clean... and still managed to be fast.
#478
Fred - I'd say it is more in between a B4 and a Kyosho with the stability as a Losi. It is a very forgiving car. It suits all kinds of driving styles
Tony - I ran Arms level. But I can make an exact measurement if needed.
GlassDoctor - Spelling out Team Iowa with the broken A-arms was funny.
#479
Hi David, did you run 4wd at this race? If so, how was the setup?
