New ACADEMY 1/10 scale 2WD BUGGY
#1952
after reading this thread for the last few days now (started at the begining)...the enthusiasm for this buggy is amazing. i'm in upstate new york, limited tracks( now that gas is so high). i recently bought an academy sb v2 pro...and love it... but you guys are making me think about 2wd now.
was just wondering if any of you guys have setup info on the 4wd buggy as well...and any mod info.
any thing would be appreciated
thanks,
Bill
thanks,
Bill
#1953
Tech Legend
Trader Rating: 51 (100%+)
thanks,
Bill
thanks,
Bill
http://www.rctech.net/forum/showthre...143694&page=75
You can also try here as for setups for the 2wd and 4wd cars.
http://www.petitrc.com/view_news.php?id=4622
#1954
I've helped two of my friends out and noticed that some are putting the shorter shock eyelets on the top and bottom of their front shocks.
I suggest putting the longer damper caps and bottom eyelets on the front suspension as well as the rear and turn the front shock shafts two and a half turns out.
You will know if you have the wrong parts if while suspended in air the car has no droop in the front.
#1955
If you go here this site has an edible GV2 setup sheet.
http://www.petitrc.com/setup/academy...cademyGV2.html
#1956
Tech Legend
I don't think that saving this setup sheet is allowed. You can print but you cannot save it so I can't post it. My friend ran my setup, which is pretty much aerayls setup cept for a few tweeks and oils, and took the win today. I wish I coulda raced but have school on Tuesdays now.
#1957
Tech Legend
Finally this upcoming week I can race if the weather is nice. Been 2 weeks off for various things so will be nice to finally race and try all the new stuff out.
#1958
Suspended
i love my gv2
it handles ausome yiurns on an dime and can easily plant the power
i finish 3rdi n the c main at the roar reginal race at vineland saturday
i prob could of made the B main if i had more track time than the 2 packs that morning
but the buggy definitly impressed me
#1959
Tech Legend
i love my gv2
Ever sine I found that problem my car has been better and laptimes are alot better to. I won't ever make that mistake again.
This weekend will be the added weight in my car with my new lipo plate. Now the car will weigh like I had 4600's in my car so I expect to see my car be better than ever this weekend.
#1960
Suspended
Hey i've got a GV2 with Diggity Designs carbon fiber parts. I'm going to the ROAR Off-road Nats and I was wondering what kind of setup should I put on my car to start out. The track (Hot Rod Hobbies) is high bite, blue groove, and dusty. The tires that work at the track are red BK Bars in the back and Silver Taper Pins in the front.
Thanks,
Chris
Thanks,
Chris
#1961
Thanks,
Chris
Thanks,
Chris
#1962
Tech Legend
Hey Fred post your setup sometime if you have a chance. Interested to see what you ran vs what I ran at Vineland last time.
Once I run this week at PitSTop I will post my new setup.
Brian
Brian
#1963
front
30 deg front block
outside on caster block, middle on bulkhead with 2 .030 washers
shocks outside, outside
56 pistons 35wt losi oil white spring.
1mm droop 1/2 oz of weight on bulkead
shaved chassis and servo saver to get full lock
front tires
j concepts grovy green
rear
0 deg antisquat (mod)
middle on hub inside on bulkead with 1 .030 washer
shocks middle on arm 3 on tower
56 pistons 32.5 losi oil white spring
bones level
rear tires
Proline inside job r3 or j concepts double dees green
30 deg front block
front tires
rear
bones level
rear tires
#1964
Tech Legend
Thanks Fred. I liked the little heavier oil at Vineland to. Double Dees didn't seem as good to me in the rear. Holeshots for the day I was down.
Cool I will post mine after I run Saturday incase I make any changes.
