New ACADEMY 1/10 scale 2WD BUGGY >
Old 03-03-2010, 03:20 PM
  #3406
jw_rooster's Avatar
glad to hear that Chris! close tracks are good tracks My news is that I just got a full CF treatment from Diggity Designs. They have some SWEET stuff guys. I love the fit and finish of their products and I highly sudgest any GV2 owner get their performance upgrade kit that includes front and rear shock towers, battery strap and steering rack. While you're at it get the motor mount plate. This weekend when I was rebuilding my buggy, I noticed the aluminum motor mount plate was bent slightly, (no wonder I was experiencing spur gear wear)
I have been running this buggy for about 3 seasons now, so obviously things will wear out, but that being said the durability of the car is not an issue for me.
jw_rooster is offline
Old 03-07-2010, 06:25 PM
  #3407
Suspended
Yeah Josh I had all of the Diggity stuff on my last GV2. I was running the 4mm towers, but for some reason the rear tower is 4mm taller than the stock so it made my car ride like one of those tail dragging 64 impala low riders. I wanted to email Diggity and see if they could make some 4mm thick towers that retain the stock geometry. I have just been running the stock stuff, but I put longer screws through the top of the shock the other way, then a non-lock nut, then the appropriate spacers, then the shock bushing, and finally a lock nut. Basically it is setup like a Losi or Associated. Get rid of the stock Academy screws as they bend too easy. The Stainless ones that come with the Diggity stuff bend too.
Yesterday was the opening day for the indoor off-road track at amainhobbies. It was so awesome. The facility was really nice and clean. It has a well stocked snackbar, clean bathrooms, and you could order parts and they would go get them for you right then, and they don't charge anything to race. Not to mention amainhobbies is located in Chico, CA which is world famous for Chico State, a HUGE party school, as a result of that there is a hot girl that works the register for the snackbar, and she orders your parts and pulls them from the warehouse for you! As for the track itself, we stayed on slicks all day and had more traction than we knew what to do with. I went from 25 to 27.5 degrees of caster to calm down the steering, and moved my rear hubs forward 1mm to get some more rear traction. By the main my car was dialed. I qualified 5th, and finished 3rd. My car was a bucket though, the shocks are in dire need of a rebuild and my diff is self destructing, so I ordered a bunch of parts while I was there and I am going to rebuild her from the ground up. I am going up 5wt on the oil all the way around and switching to the black Academy springs all the way around. Basically the same setup I was running in Columbus, OH. I have a few more ideas for some stuff I wanna try. It is so nice having such a great facility open up, my desire to race has been renewed. My former "home" track was run so terribly (i'll spare you guys from the details, but if you can imagine a problem, this track had it). The only reason I ran there was because it was the closest electric off-road track. It was the same for most of the racers around here. Yesterday was like being set free, after being enslaved for the last five years (how long I have been running at the other track).
ifuonlyknew is offline
Old 03-07-2010, 06:52 PM
  #3408
jw_rooster's Avatar
Diggity offers a rear shock tower with the same geometry, but not a 4mm thick one. I too have the 4mm thick and taller rear. It takes some of the down travel out of the rear of the car (the GV2 has a lot of down travel) I tested it on the track and noticed the car reacted quicker and had a more direct jumping and turning feel. Everybody drives different though, so maybe it just didn't work for you. I got some ceramic diff balls recently and planning on sending my diff rings to B Fast soon to try and build the perfect diff for this car. I need to get it bullet proofed because I am going to be doubling up stock and mod in the super cup series.
Old 03-07-2010, 09:41 PM
  #3409
alana07's Avatar
Trader Rating: 53 (100%+)
the GV2 has a noisy drivetrain despite the gearbox and its internals being new, both new spur and pinion gears. so what makes those noises? any possible solution to solve this? thanks.
alana07 is offline
Old 03-08-2010, 04:13 AM
  #3410
jw_rooster's Avatar
My GV2 is super quiet. I don't know what kind of sounds you are referring to, but I would say to check your gear mesh of the pinion and spur, make sure your diff and slipper are functioning properly and adjusted accordingly. and that everything is bind free and spins smooth and free. Make sure your top shaft isn't bent as well as your motor mount plate, that would definitely make it noisy. Hope this helps.
Old 03-08-2010, 06:26 AM
  #3411
alana07's Avatar
its basically a whole gearbox rebuilt with new parts n everything's rolling smoothly. Pinion/spur mesh was spot on as well, just that when the car's running the noise is louder compared to a B4 or RB5...
alana07 is offline
Old 03-08-2010, 07:13 AM
  #3412
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
anyway you can shoot a vid of it or even just a sound file so we can hear what you are hearing?
Cain is offline
Old 03-08-2010, 03:26 PM
  #3413
rdub202's Avatar
Trader Rating: 19 (100%+)
mines been noisy too. my motor plate is a little bent which could be the issue though.
rdub202 is offline
Old 03-08-2010, 03:29 PM
  #3414
Try a new top shaft. Just an idea.
rtraceshop is offline
Old 03-08-2010, 06:43 PM
  #3415
Trader Rating: 126 (100%+)
Hey fellas with the noisy trannies. Is the gear mesh too tight? Do you lube the gears in the tranny? I NEVER run them dry. This is what I use. AC-1001 Super Speed Gear Lube . It can be found here or thru your local LHS.
http://www.aerocarlubricants.com/
Josh this was the secret that made my stuff soo much faster than yours. Worth the extra second. J/K.
kwiksi is offline
Old 03-08-2010, 06:51 PM
  #3416
alana07's Avatar
basically its a whole new gearbox setup, including new motor plate and top shaft...
gear mesh is spot on using the paper-in-between meshing method. internal gears are lubed with HPI's graphite lubricant...
alana07 is offline
Old 03-08-2010, 08:23 PM
  #3417
Tech Legend
Cain's Avatar
maybe your gears need to be ran in a bit?
Here are some pics of the B-Fast ring next to a used standard ring:
As you can see, the B-Fast ring is much flatter surface compared to the stock ring.
Cain is offline
Old 03-08-2010, 08:42 PM
  #3418
Tech Legend
Cain's Avatar
I just rebuilt my first diff with the rings. This is a diff with ceramic diff balls that felt decent previously, more friction but not full on gritty.
With the new rings, I have it tighten down pretty good and its BUTTER smooth.
I am going to build another diff using standard balls and see how that compares.
Cain is offline
Old 03-09-2010, 04:47 AM
  #3419
jw_rooster's Avatar
oh really??? thats funny dave! Too bad you can't bring that new Schumacher down here for me to drive circles around! I would hate for you to get beat by your old team mate (again)
Did you go to rochester with Barron?
Old 03-09-2010, 04:50 AM
  #3420
jw_rooster's Avatar
I can't think of anything else that could be causing it. Seems like you have the obvious things covered. What kind of pinion spur are you running?
